LED lights 190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: LED lights 190XT
    Posted: 17 Sep 2020 at 8:11pm
Forgive me I am sure this question has been on here before. I tried doing a search on the forum but quickly became frustrated. So, I would like to upgrade my 4 sealed beam lights on my XT. I am looking for lights that look factory, not ones that have 4-5 round LED lights in them. Any help would be appreciated.
Robbie
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:25am
That sight doesn’t have what I’ve seen before. The LED light I saw before looked just like the sealed beam light.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 6:49am
Is this what you are looking for. https://www.larsenlights.com/par-36-fluted-lens-45-led-18-watt-flood-light
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:25pm
Thanks Lonn, those are the ones that I was looking for. My brother Charlie saw those as well. I think I am going to order 2 to see how I like them first.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:33pm
Will these lights have the "2 tier" brightness that the originals have ?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:41pm
Looks like you need the bolt on back housing to go with it.
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:54pm
The ones I posted are flood lights. I couldn't find the ho/lo beam ones. If it were me I'd just call the company.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 7:55pm
They fit in the old housing
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 8:08pm
I haven’t paid attention the lights having 2 tier brightness? Just the inside ones also coming on the second click of the switch. Guess I need to check that out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 5:47pm
Yes, there a 2 bulbs/side that come on in the first position of the rotary switch, but the second position lights up another filament in the "outer bulbs" ?? Pretty sure someone will "confirm or chastise " me on my memory LOLLOL.
WD in Australia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in Australia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 11:28pm
Another option I have found but not tried as yet. LED bulb.
Depending on the light means you can keep original light but get LED benefit.
WD(NF), WD45(WF), WD45D(WF), XT190D(WF), Model U, Gleaner C, All Crop 60, Rotobaler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:18am
On mine, the 2 inboard lights come on first, second click the outboard lights come on also.
I could see the above option with the first series that only had 1 light?
Charlie
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:56am
<div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;">
I have them in one of my cubs. It is still 6volt so not real bright, but much brighter than the filament lamps. Now that I think about it, should try it in one of the 7XXXXs 12v hi lo lamps and see what that looks like.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 7:29am
My brother's 1970 190XT, the first click the inboard front lights come on dim and the flashers flash. The second click the inboard lights go to bright and the flashers still flash. The third click the inboard lights stay on bright, the outboard lights, which are flood lights, turn on, the rear lights turn on and the flashers turn off.
Wink
I am a Russian Bot
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 9:47am
The factory used 2 different bulbs. Inners were trapezoid (4411) and the outer were flood (4406) I think.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 3:13pm
I got those style LED's like LONN showed on my 3020.  They work great.  Much better than the original bulbs.  There is no high/low beam to this light.  It is either on or off from what I've seen and guessing the same for those.  I like the ones with the panels on the light housing as showed by Lonn.  Really can't tell their LED's until you turn them on.  It keeps the original look. I'd recommend.  I also put them on my White 105 and got a few on my R50 combine. Those I have the regular LED's without the panels on the light housing.  Really have not noticed any difference in light output between the two.
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 4:33pm
I'm not sure they are all like this but I suspect most are.  If you look on the back of the light switch there will be a coil between two of the terminal points.  The lights are dim because the voltage to them is routed through that coil on the first setting.  The next setting bypasses the coil so the lights see full voltage.  The third setting turns on the flood lights.
Having said all that, the current draw for the LEDs is much less which makes the voltage drop across the coil much less for "dim" operation so you wind up with essentially full brightness in both switch positions.  If you want to fix that, you'll need to replace the resistor on the back of the light switch with something larger.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 5:08pm
The 190XT with dual lights did not use 3 terminal lights with high and low beam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:22pm
YES !!!! That's EXACTLY what's on the back of a 100 series light switch WinkWink !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 7:24pm
Interesting, always wondered what that thing did. Thanks Flyer. Not only do I want to get brighter lighting, I use the rear plug on the fender to power 2 magnetic warning lights that I place on equipment behind me. When I do that now, if my ride is over 20 minutes it has melted the fuse holder and burn up 1 light switch. With the LED’s drawing less amperage, I am hoping to resolve this issue also.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:18am
I put the high/low led lights on my 200. There are 6 led light bulbs in the high/low lights I bought. With the switch on dim only 3 bulbs turn on, then in high beam all 6 bulbs come on. They do not have the original look though.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:34am
I think my brother's XT does, I don't remember for sure. I did replace the switch on it once but never use the lights much on that tractor. I'd rather have 3 terminal bulbs than that coil resistor.
I don't like the light switch with the resistor coil as I've found the new switches don't last like the old ones because, I feel, they over heat...... Maybe because they weren't made for halogen lights. My 200 burned through two switches until I replaced the high/low bulbs with LED.
Also, for those who may wonder, the little doohicky showing the positions of the switch says: OFF, H.L. DIM, H.L. BR., and F.L. That's four positions. I assume H.L. means head light, B.R. means bright and F.L. means flood lights.
Wink
I am a Russian Bot
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 12:43pm
I would agree.  The reason the switches didn't like the halogen lights is that they were likely a higher current draw (lower resistance) than the standard filament bulbs.  The heat dissipated by the resistor coil increases by the square of the current (I2R).  So a 10% increase in current would result in a roughly 21% increase in heat from the dropping resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 5:45pm
Am I wrong that the original filament bulbs did not have a 2 filament bulb for the "bright" setting like an old school auto/truck headlight ? I just assumed that the "brights" were a different filament in the same bulb getting kicked on Smile Never gave a thought about the "spring" on the back of the switch changing the output of the "same" filament LOL !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:04pm
Spoke with Kenny Larson this afternoon about the par-36 lights and said they should be a direct replacement. I think I’m going to pull the tricker and get 4. I was going to replace the flood in the rear but it has the red stop bulb in it and I want to leave it factory.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 8:11pm
I replaced the rear flood on mine with a 2-color LED.  I have it wired for red for the first two light settings.  In the flood position it switches to white.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 8:16pm
What year did the red bulb go away on the rear fender light ? Our '68  XT has no red bulb, now that I think about it, neither does the '69 180 Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 9:06pm
Mine is a 1968 and it has it. Yours may have got changed out.
Let me correct myself. Larson par36 fluted lights are flood lights not projected lights. Kenny feels I should get up to 30 feet of light. I rarely do any night time work, I use the lights and flashers driving to fields. My main reason to upgrade to LED is to take the stress off of the wiring and electrical system since I use the rear plug to power 2 magnetic flashing lights I mount on equipment behind me while traveling on local roads. These LED’s are fluted resembling the factory lights which is important to me to keep the factory look.
Interesting to know a red/white light is available for the rear.
Edited by AC720Man - 26 Sep 2020 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 9:11pm
Our XT has amber top fender mounted flasher ??
This page was generated in 0.108 seconds.
