One-Sixty 160 lift arms will not lower
tate007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tate007 Quote  Post ReplyReply Direct Link To This Post Topic: One-Sixty 160 lift arms will not lower
    Posted: 15 Sep 2020 at 2:22pm
Need recommendation how to get the lift arm on my Allis Chalmers 160 to function properly. Tractor starts and the lift arms raise but will not lower. I even tried to weigh them down with an implement with no luck.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 10:35pm
takes pressure to make the valves work  - loosen the line on the top of the pump and see if has lost its prime  - due to worn pump and or stopped up strainer under the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tate007 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 12:10am
The lift arms will lower after the pump line was loosened. Or let it sit idle for a day or so. The strainer was checked.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 11:57am
I'm not familiar with the 160 hydraulics, but have you checked the position control linkage to see if it is working properly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tate007 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2020 at 8:30am
Please recommend a manual to help me troubleshoot this lift issue. I really would like to be able to use the lift.
