F Combine ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F Combine ?
    Posted: 14 Sep 2020 at 6:55pm
We ran a '70 (?) F combine with the 292 gasser in it. Any idea of why ALLIS didn't put their 180 gas tractor engine in them ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 7:31pm
Id say power,, you get a Gleaner F loaded up it makes that 292 talk,,and it sounds awesome
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 7:35pm
It REALLY talks when the RHS countershaft bearing fails CryOuchConfused, I've got a feeling that when that bearing failed and if dad was in the seat, the F would have been a smoldering heap in the field Shocked !!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 9:26pm
They put a 301 gas in the early G model but the early F gas got the old D19 262 gas engine at 93 hp. I'd guess that the Chevy 292, as popular as they were, were cheaper to buy than Allis building a 262, 265 or 301 gassers.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 8:44am
Pretty sure the move to GM engines coincided with the fact that the Harvey Engine Division either was going to drop all gas engines from their product line, or already had dropped the gas engines. I think it was 1971, not 70.  The 175 gas engine was built in West Allis, not Harvey, Illinois.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 9:21am
 My take as to why the AC 301 was dropped from the engine line up was that the 292 chevy was way cheaper to buy and very few 301 gas engines where being built. All of the other gas engines continued to be built while I was there.
Edited by ACjack - 15 Sep 2020 at 9:23am
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 12:48pm
The biggest reason was price, because the 301 gas engine was built on a diesel frame and was more expensive to build.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 1:34pm
And was easily overhauled because of wet sleeves. Think about it. How many combine engines get the amount of hrs a tractor engine usually does ??  So the less expensive GM engine made sense.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 9:48pm
As a trivia point the GM engines were industrial units.  Several items like timing gears instead of timing chains made the units different from auto engines.  We bought a few of the engines when Gleaner dropped the gas versions - if memory serves correct they sold them at 500 below cost $750 for the GM250 and $875 for the GM292 no carb or gov..  They were a real eye catcher in the frame on the showroom floor. ... could have sold 10 times what we did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 6:08pm
OuchCry, the F we acquired had a replacement 292 out of an auto salvage yard per the seller Sleepy. I can verify that it was an "auto" engine because they never bothered to swap the oil pan for the hose drain set-up that Gleaners have Wink. Trust me, that was a REAL mess to change oil ShockedShocked !!
This page was generated in 0.031 seconds.
