7060 cummins conversion
Dafydd7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 cummins conversion
    Posted: 13 Sep 2020 at 4:51pm
Hi
Just wondering if anyone on here can help me
Taken the engine out of my 7060.
I noticed on the 7060 clutch there is 1 belleville washer/spring and on the conversion kit I had from usa there are 2 of these washers.
Does anyone know which way I should position these washers cos I have no idea!?
Never fitted a clutch with one of these washers before!
Any info would be much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 7:25pm
The curve out on outer edge. Stands pulling edge to flywheel on outer diameter .           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 10:43am
Hi
Thanks for the answer
Would you be able to send me a simple drawing? Bit thick over here!
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 12:44pm
Belleville faces away from flywheel...cup out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 4:01pm
Thanks for that
Do both washers face same direction?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 5:52pm
Yes
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 6:26pm
Dafydd7060, which Cummins engine are you using for its conversion - 5,9L? - 8.3L?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 8:08pm
You will have to shim stands if you use two Belleville washers.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 1:45am
8.3L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 1:51am
What do you mean by stands?
Is it the bolts with bushes that holds everything together?
Apparently, the conversion kit we bought has been recessed more to take 2 belleville washers.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2020 at 7:43pm
I would talk to your supplier about stands and shims. When I put 2 in mine had machine shop make new ones xtra length equal to thickness of extra washer.
