Power steering fluid agco 7600?
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: Power steering fluid agco 7600?
    Posted: 13 Sep 2020 at 3:05pm
Just purchased a agco allis 7600 it’s low on power steering fluid, I don’t have a manual and was curious if anyone knows what it takes
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 3:57pm
we always used the older automatic trans fluid... AFT / type F / Dextron III .
johmor15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johmor15 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 4:08pm
manual says atf dexron for steering also brakes ,don t use brake fluid or else you will be replacing the seals in the brake pistons I already went thru that
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 8:10pm
Thank you guys
