Steering issue with a 175D
old AC friend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old AC friend Quote  Post ReplyReply Direct Link To This Post Topic: Steering issue with a 175D
    Posted: 07 Sep 2020 at 12:06pm
My 175 isn't steering right.  It seems to want to steer to the left and will turn left easier than right.  It takes many revolutions of the steering wheel to get a change in the direction I want to go.  Is this an orbital issue, check valve issue, or both?  The front loader and the 3 pt. works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 3:18pm
New seal kit in the steering cylinder. I assume your cylinder is crossways under the engine attached to the tie rod, right  ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote old AC friend Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:27pm
Thank you Dr. Allis, you are correct on the location of the steering cylinder.
