7010 vs 8010 what’s different
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: 7010 vs 8010 what’s different
    Posted: 06 Sep 2020 at 8:27pm
What was different besides cab and sheet work from 7010 and 8010 tractors?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 8:36pm
That’s basically it besides hydraulic couplers and a few other minor things
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 8:39pm
Aren't the power shift valves different?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 9:33pm
Ok I wasn’t for sure if anything had been updated.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 9:34pm
Injector pump?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 10:03pm
8010 Power Director is electric over hydraulic verses cables on the 7010.
Edited by Lonn - 06 Sep 2020 at 10:03pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 7:55am
The hydraulic valve stack is completely different and operates under a different priority system than the 7000 valves did. The Power Shift valve got some nice upgrades.            Injection pump and engine oil cooler were different on the latest models, the last year of build ??  Power shift trans got larger gear bolts on the rear clutch housing and one less gear in one planetary. Air cleaner had an optional exhaust aspirator. Fuel tanks were 20 more gallons in capacity.
