Front tires for 190XT
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Front tires for 190XT
    Posted: 24 Aug 2020 at 6:29am
Had one side go flat and I noticed it has a lot of dry rot on the inside face. These are 7.50 x 16. To use the same rim can I go to a larger tire or will it rub due to the limited offset of my rims?
Common sizes seem to be 7.5x16, then 10x16.
Plan to stick with a tri-rib design. Carlisle tires seem to look nice.
Plan to replace both sides
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 6:33am
I see Cropmax 7.5 are 8" wide and 10's are almost 11" wide.
don't think I have 1.5" of clearance. Have to measure to be sure.
Charlie
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 8:09am
My 185 has 9.50L X 15 if you can find a set of those rims they should work on the 190 too
if you want wider tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:11am
Looks like I need 4" backspacing to use a 9.5/10 tire
The 7.5 has 4.75" backspacing
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:31am
Charlie I looked into this a while back. As Gary said a 185 wheel, also a 200 and 7000 wheel will work. I was looking for a set off of a 7000, haven’t found any locally. Found some in Pa but that’s a ways to go and they didn’t want to ship them.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 9:49am
I believe the wider rims will have an offset center.  This should allow you to go with them.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 10:59am
My 190 has 9.50x16s on it the rims on it are mounted with the valve stem on the inside.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 11:07am
my 190 has the 10:00 size on it and dont rub,--but you have to have the right rims.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 11:13am
I have 10.00-16 on WL8-16 wheels with 5/8 offset on both my 190 and 200. With the 1 1/8 offset you have to reverse the wheels.
The 7.50-16 uses a 5.5 or 6 in wide wheel.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 11:14am
A word of advice from an old tire dealer. Stick with the 750x16's on your XT.   The Carlisle tires I sold in the past had a thin casing. Don't know if they have improved them. If you buy them, put them on and don't get into the corn/bean stubble till next spring. They do need time to harden up. If you need to take it to the field right away, look at Firestone's. They seemed to pickup far less stubble damage than most other brands. If you do switch tire sizes, make sure you get rims from a tractor, not implement rims. Tractor rims have a heavier center plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2020 at 11:58am
Thanks for the help. Not stubble for me, just hay fields and bushhogging lots.
Charlie
