weed killer concenrtate |
Page 12> |
| Author | ||
Rusty Allis
Bronze Level Access
Joined: 16 Jul 2020 Location: Rhode Island Points: 170 |
Topic: weed killer concenrtatePosted: 13 Aug 2020 at 3:49pm |
holy hell...
went to go get some roundup total vegetation killer (for around walls that are a PITA to deal with) 125/gallon locally guess the real question is, what do you guys use that kills stuff dead? going in a 25 gallon sprayer mounded on a ATV. last time i bought a gallon of it (2 years ago?) it was like 45/gallon and that was concentrate too. not opposed to using a home brew, you know like gretta thunburg tears, wombat piss etc, just want something that works and kills everything |
| Sponsored Links | ||
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89171 |
Posted: 13 Aug 2020 at 3:57pm |
I use the Generic Glyospate.... like 43%...... buy at Farm Store for about $50. for 2.5 gallons......... at least it was 2 months ago.
HoughMade
Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 714 |
Posted: 13 Aug 2020 at 4:05pm |
I've been working with the same 2.5 gallons of 41% Glyphosate for 2 years. I add some methylated seed oil as an adjuct that helps it spread on the leaves and cuts through waxes and mix it a big stronger than the directions. You can use dish soap instead. That doesn't get through the waxes, but is a decent spreader.
Edited by HoughMade - 13 Aug 2020 at 4:05pm |
1951 B
steve(ill)
Posted: 13 Aug 2020 at 4:06pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54694 |
Posted: 13 Aug 2020 at 5:06pm |
Back when I was using my pesticide license, I learned that the dry formulation (round up quick pro dry) killed faster, and has no worries of ever freezing or separating. Of course, the down side was that it is more expensive...
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5909 |
Posted: 13 Aug 2020 at 6:24pm |
On Sale for $23.99 CAN. for 5 litres at our local TSC in Ontario. https://www.tscstores.com/WEEKLY-FLYER.aspx |
Rusty Allis
Bronze Level Access
Posted: 13 Aug 2020 at 8:19pm |
interesting you bring this up. I have read you can use dish soap as a surfactant but never tried, as I was always afraid to have a huge jug of suds behind me is this advantageous to do? or is the seed oil a better bet? what ratio do you mix in either case? thanks for the tips, i will check out TSC as i have one not too far. i assume it works pretty good? (the TSC stuff) i about shat myself when i saw 125/gal but it was at my local hardware store who quite honestly, is very competitive with bigger places. i do a lot of business there but that seemed pretty steep |
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Posted: 13 Aug 2020 at 9:48pm |
I saved some calcium chloride from tires and spot spray
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 13 Aug 2020 at 11:14pm |
The price on Roundup brand is due to the lawsuits against Monsanto. Generics do not seem to be affected.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 14 Aug 2020 at 5:38am |
As a side note, what are you using to help with hard water when spraying. I did some fields and had about 60-80% kill. Someone mentioned that it was due to our hard water and the chemicals adhering to the minerals in the water and not going into the plants.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 14 Aug 2020 at 6:51am |
Back when I was spraying full time with my job, my mix was glyphosate, non-ionic surfactant and Sequester (Hefty Seed brand). The sequester helped stabilize the pH in the water. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
marion
Posted: 14 Aug 2020 at 7:18am |
I use generic roundup, pioneer I think, then add some mohave, (a soil sterilizer) mix in water before dumping in tank, and then dump in a couple gallons of bleach, but wear respirator while dumping contents in tank, unless yoou want your lunch on ground.
make sure yoou are upwind whle spraying. I used this recipe to whipe out a patch of bamboo years ago, but note it will also do a 40 year old oak tree.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12326 |
Posted: 14 Aug 2020 at 7:21am |
$125 a gallon?
At what, Lowe's or something? Any feed stores/ mills around?Round Up Powermax for me this year was $38 per gallon, and that includes a surfactant already in the concentrate. "Generic" Gly-Star was approximately $17, but you needed to add the surfactants, and use a little more, so per acre was about a wash in cost. |
HoughMade
Posted: 14 Aug 2020 at 9:16am |
I use a 4 gallon backpack sprayer for this sort of thing. I use 1 teaspoon per gallon of the soap or methylated seed oil. Both work, the MSO helps the glyphosate work a little faster, but not enough to worry about. It's real advantage is if you are spraying weeds with a waxy coating on the leaves, basically anything with shiny leaves.
1951 B
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24888 |
Posted: 07 Mar 2022 at 6:18am |
poor man's roundup jug of vinegar, cup of table salt,4 caps of dish soap. mix well, apply After dew is gone and before high noon kills everything INCLUDING bindweed ! I can't legally use roundups...
Tbone95
Posted: 07 Mar 2022 at 7:53am |
"Poor man's", eh? What kind of vinegar? I would think White Vinegar would be the cheapest, no? Just looked: Meijer grocery, $2.69 per gallon. I spray 20 gallons per acre. I would assume if you dilute this like 95% water 5% vinegar, it doesn't work so well? Not to mention, kill my crop! That would indeed make me a poor man. This year is going to be pretty interesting financial wise farming, but let's call this year a flier and go with typical. I usually spend about $20 per acre spraying. Adding some tank mixes for tough stuff, maybe $25. So, if I dilute your stuff, 50-50, still $26.90 plus the salt and dish soap.....and nothing will grow? Will it work at 50-50?
steve(ill)
Posted: 07 Mar 2022 at 8:46am |
I think the big question is " what are you spraying it on ".... If your killing grass and weeks along the fence line, then most any concoction will work... If your spraying roundup ready beans / corn in a farm field, then you want the RIGHT stuff.
jaybmiller
Posted: 07 Mar 2022 at 8:52am |
White Vinegar( 'food grade') is 5%, used as is. Only $2 for 4 litres( probably 3.78... 1 us gallon). It's a heckuva lot cheaper than Roundups......
ac hunter
Posted: 07 Mar 2022 at 9:11am |
Will the vinegar brew kill poison ivy? Have some in my garden around the asparagus and rhubarb. Wouldn't want to kill those too.
Tbone95
Posted: 07 Mar 2022 at 11:19am |
Maybe....you didn't answer the question of how concentrated it has to be! Your concoction makes no mention of water! I put a quart of roundup in 19.75 GALLONS of water, for about $10 per acre. And I'm comparing PowerMax brand name roundup! For supply store / generic stuff, I would bet you could do more with $5 worth of it diluted and used properly than you could vinegar.
Edited by Tbone95 - 07 Mar 2022 at 11:24am |
Tbone95
Posted: 07 Mar 2022 at 11:20am |
Well yeah! But....what if I want to burn down a field? No crop in it yet. And how long before something will grow? And besides......it's fun talking to jay about this kind of stuff.
jaybmiller
Posted: 07 Mar 2022 at 11:46am |
re: you didn't answer the question of how concentrated it has to be! whatever it says on the jug ! You do NOT water it down, use at full strength, which I think is 5%. You dump a cup of salt into the jug of vinegar, mix really well, then add few squirts of dish soap, mix really well, pour into sprayer, then use after dew is gone and before high noon. If you want really,really cheap 'vinegar', buy a 45 gallon drum of acetic acid, then dilute it to 5% (same as grocery store bought vinegar). dilute to 10%, then it'll be twice as strong as store bought. BTW ...It kills EVERYTHING..it is NOT 'selective'. we got stupid laws up here... I can't use 'roundup' but golf course can...
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 07 Mar 2022 at 12:36pm |
![]() ![]() ![]() ![]() Another 2 year old post back up to the front. So Rusty Allis has been smothered by the weeds or has them under control. But since T is having fun if J is also keep at it.![]() ![]() ![]() But the fastest weed killer I ever saw was old rotten gas. Had bucket as I cleaned from a old gas tank. Got the bright idea to use a back pack spray to not just dump it and have a hazardous waste site. Some nasty tuff weeds that grow in the summer months after our rain stops and it is 100 degrees for days. Walked out from the yard spraying, by the time I got done with the first 2 gal they where brown. But with price of gas and then letting it "brew" for 5 to 10 years and the evaporation, a rather expensive way to go.
Tbone95
Posted: 07 Mar 2022 at 12:48pm |
Which is what I thought, which EASILY proves my point that Roundup concentrate is actually cheaper to use for my price, which I would presume is close to the price most guys on here pay, not Crazy Canuckville prices.
steve(ill)
Posted: 07 Mar 2022 at 12:50pm |
When diesel was $.30 per gallon, we use to mix Roundup with that to spray fence lines and driveways.... no water.
jaybmiller
Posted: 07 Mar 2022 at 12:59pm |
As I said though, I can't USE Roundup....agin the law up here, also can't USE 2-4D either. Welcome to Canada,eh !!! |
Tbone95
Posted: 07 Mar 2022 at 1:13pm |
Yep, I know. Heard ya. And as we know, Canada sucks.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3953 |
Posted: 07 Mar 2022 at 2:57pm |
We can use Roundup here in Alberta. Must be an Ontario thing
jaybmiller
Posted: 07 Mar 2022 at 3:07pm |
Yeah ,lovely Ontario.... Any golf course can use ANY amount of tap water and chemicals... ...'regular' folks have huge restrictions. NOT agin the law to import, buy, store 2-4D,etc..just USING it... currently getting fresh crop of 'white nitrogen' as I type though..... ..thanks to the man and his 'machine'....
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8463 |
Posted: 07 Mar 2022 at 6:46pm |
Maybe you need to to the paperwork to declare your farm as a golf course.... :)
Page 12> |
