top speed
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: top speed
    Posted: 12 Aug 2020 at 5:28pm
I am going on a tractor ride.  Will I be able to keep up with red and green?  What is the
  theoretical top speed of my D-12 III with over/under and 14.9/24 rear tires?
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 5:37pm
I don't know if this helps or not, but on my CA with 12.4 X 24 in 4th gear using my GPS in pedestrian mode it shows 16 mph. Could be comparing apples to oranges but it may help you.And I'm not sure of the accuracy of a GPS on pedestrian mode,, I do know it is as fast as I want to go on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:07pm
You're looking at 15.0 MPH @ 2,000 RPM with a 12.4 x 24 rear tire. No, you cannot keep up to a legit M or Super M Farmall.  If you increase your engine speed to 2,200 RPM, then road gear is 16.5 MPH. Now you can keep up with some M's.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:07pm
All rides I have been on they  have a speed limit, anything from 10 to 15 mph, I think it is not a race, its for enjoying the ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:32pm
I go on several each Summer and 14 MPH seems to suit me the best. Don't have to run full throttle, but fast enough to cover some miles. The 10 MPH thing is sooo bad, I won't go on one anymore.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 8:53pm
I have a D-10 series III with the Hi/Lo gear box in front of the standard 4 speed transmission. I drive it on tractor drives/caravans, It will 16-1/4 mph.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 8:57pm
The HI/LOW gearbox does nothing for the top speed, as it is direct drive when in HI. A regular 4 speed has the same top speed. Rear tire diameter and maximum engine RPM dictate how fast it will go.
Edited by DrAllis - 13 Aug 2020 at 10:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 8:38am
Thanks Doc. I just learned something. I had always figured that the Range Transmission ( two speed gear box was a straight/over gear box.
Dusty
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 1:39pm
I've had my D10III w/ range in one ride-my last ride!
If I get talked into one again the tractor will be on the trailer and ride in the cab.
The variations in tractor speeds over the years for the different models won't allow uniform speed.
highly unlikely you'll ever go top speed unless you stop at a roadside park, take a nap and want to catchup.
Edited by JoeO(CMO) - 14 Aug 2020 at 1:42pm
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 5:28pm
I know the guy who leads the two local rides I go on, he has some Allis and knows how slow they can be so he usually puts me near the front to set the pace. Any smart tractor ride will either split into groups or put the slow tractors up front and just go their speed.
