WD-45 SR #
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 SR #
    Posted: 11 Aug 2020 at 8:12pm
Hi everyone.
Somewheres I seen a post showing a picture of the serial number. Could someone post a picture of it. I myself know where it is but I can't get to tractor and want to show my nephew where to look. Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:14am
http://www.tractordata.com/farm-tractors/000/0/1/10-allis-chalmers-wd.html ; Scroll down to the serial numbers and click "photo of WD serial number "
AaronSEIA
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:16pm
There you go. Back of tractor left side right under the open hole with the spring showing. On the flat right between the 2 bolts. You will have to expand pic a bit.  That one is mine. 175421.  πŸ˜€
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 6:19pm
If you look carefully you will see the WD just before the number.  Bit easier to see in real life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:12pm
Perfect, thank you. Hard to explain to a ten year old. Might be getting him a new tractor. Gotta see what year it is.
Thanks
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 7:32pm
You might have been thinking of Bryan Smiths web site:
http://wsmth.people.clemson.edu/SNLocat/ACSN4.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 8:38pm
Post the number if you can get it and I will tell you the year. Or lots of guys will. πŸ˜€
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 6:46pm
Haven't had a chance to look at sr no. of that tractor.
What kinda value are the wd45 going for. It's a one family owned tractor. I know what dealer it came from. Been inside for as long as I can remember, and if I remember right tin is all straight. If the pain isn't original then it's an old repaint. Looks its age. We have to double check the rims, don't think there bad. Wide front, wheel weights. Has snap coupler 3 bottom plow and disks. Back in the day was rebuilt with d17 engine kit.
Edited by Mikez - 04 Dec 2020 at 7:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2020 at 9:15am
Really hard to put a value on some of this stuff. At sales now this old stuff seems cheap most of the time. $1200 to $2000 on a good day will buy a WD45.  If you find one in real nice shape then more. You have to decide what it’s worth to you. Looks like you are getting some implements so that is added value. These old tractors are real good value and will do a lot of work if you have the right job for them. If you need modern hydraulics then not so much. Hope you get it. πŸ˜€
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 2:11pm
it looks like a 1955 sr# WD204424
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 4:39pm
Yes it is 1955. πŸ˜€
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2021 at 11:25pm
Being in good shape, and a one owner, I'd say $2000 is a really good price if you can get it for that, along with the implements.  GOOD luck Mike!!
