PTO overrun clutch
Pete32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Topic: PTO overrun clutch
    Posted: 07 Aug 2020 at 7:39pm
Does anyone know if they sell parts/ repair kits for these? I bought a new one, but the one I had came apart while brush hogging and I couldn’t find the inside parts for it. Thanks in advance
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 7:54pm
I've never seen individual parts listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 5:36am
Obvious place to start would be the manufacturer but I suspect for 'safety' or 'legal' concerns they don't sell 'repair' parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 8:01am
Thanks
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 9:48am
as far as I can find out---if it explodes ------- buy a new one. ---- another "throw-away" no parts item---sad but true.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 4:39pm
Buy a new one. 4 people I know have been killed when those failed. Running n ferds. Pushed over steep embankments. Buy a good unit. Store it inside.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 4:53pm
Wow.....you know (knew) a lot of unlucky people!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 5:08pm
That's the nice thing about my WD45....never pushed around because he "handy" hand clutch is the stop-start method.
Terry/EasternIa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry/EasternIa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 5:58pm
What doe's the over run clutch do? What is the purpose of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 6:37pm
It lets the pto shaft on the equipment keep spinning when the clutch is disengaged while the pto is spinning.  This keeps the inertia from something like a bush hog from pushing the tractor through a fence, into a ditch, over a steep embankment, etc. On the older smaller tractors the pto is driven straight though the transmission and even with the clutch disengaged the spinning equipment will keep driving the tractor and the brakes are not enough to stop it. At best it is a bad feeling to try to stop and go right on through that new fence you just put up, worse it the tractor going for a swim in the pond.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 9:09pm
Brian I knew several very unlucky people. One of them was my fishing buddy in 1963.
