6 to 12 volt conversion ?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: 6 to 12 volt conversion ?
    Posted: 03 Aug 2020 at 9:32pm
Little confused on the 12 volt coil w internal resistor. Why do you need a resistor if you have 12 volt battery w 12 volt coil?
I used to be young and stupid, now I am not young anymore.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:41pm
12 volt coils were made with and without resistors. The early chevys had two wires going to the coil. One wire came from the terminal of the starter cap 12 volts hot to the coil boosted spark for starting the other wire came from the ignition switch had a resistor in the wire dropped to about 9 volts for continuous run if you ran that (12 volt coil) without a resistor the coil would burn your points to a crisp
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 9:49pm
As long as your coil is 3 ohms across the primary terminals no ballast resistor is needed on the 12v system for a 4 cylinder application.Some 12v coils were internally resisted and some were not.Check your primary resistance.
Edited by ac45dave - 03 Aug 2020 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 7:20am
Ballast resistors didn't work under the hoods of 60's Automobiles, never mind out in the elements on a Tractor.  A 4 cylinder on 12V's needs 2.7-3.3 ohms of resistance in the ignition circuit in order to run correctly. Using an internal resisted 12V/3.0 Ohm Coil on your conversion keeps Mother Nature from messing with it. External Ballast reistors play havoc in high humidity area's as well as on rainy days. Engine missing, no starts, etc. are all part of the havoc Mother Nature plays with an external ballast resistor.  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 7:39am
OK, so changing a WD 45 from 6 to 12, I want a 12 v coil w internal resistor - that right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 8:00am
re: I want a 12 v coil w internal resistor - that right?
that'll work fine, just be sure to remove the exiting ballast resistor !
'old skool' ballast reistors did tend to fail, due to the ceramic casing.
I've used Vishay Dale chassis mount resistors for decades with zero failures. These are neat ORANGE anaodized aluminum cases with the resistor inside. totally sealed, solder lugs on the ends, 2 offset small mounting holes.  On the D14 I sold, I had a 50Watt version hangin between the coil and dist. They also have a 100W version.
As long as you limit current to about 4 amps, you'll be fine.
Jay
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 9:19am
As Steve said....check primary (the + and - terminals on the coil) winding of your 12v coil. Resistance between those terminals needs to measure about 3 ohms for the WD45 (4 cylinder engine). If it doesn't, go to your favorite auto parts store armed with your ohmmeter and find one that meets the 3 ohm spec. Discard any external resistor.
Edited by Dave(inMA) - 04 Aug 2020 at 12:48pm
WC, CA, D14, WD45
This page was generated in 0.199 seconds.
