Generator on D17 Diesel (early)
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Topic: Generator on D17 Diesel (early)
    Posted: 03 Aug 2020 at 12:12pm
So I'm starting to consider rebuilding the generator. I've lived with it not working (tried re-polarizing, etc) but it's starting to bug me more.
What's the best way to deal with the power steering pump? Do you just unbolt it from the back and leave it in place, or so you have to remove it's lines, plug them, and take it off with the generator?
1957 D17 Diesel w/ M&W Pistons
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 12:17pm
Remember chevy used this same setup during that time period...
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 12:32pm
Just unbolt the PS pump from the back. There is a splined coupling that drives the pump.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 2:12pm
That's what I'd hoped, so there's enough give in the hardlines to get it off?
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 2:21pm
My mate has a 57 Chevy Bel-Air, can I rob the part of it?
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 8:30pm
Actually, and more likely. Does this mean they make an alternator with a rear spline shaft as well?
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 7:43am
For the benefit of those reading the thead in years to come, and who have way more money than I do, here it is:
Or
Edited by Coke - 04 Aug 2020 at 7:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2020 at 9:50am
Yes, there is enough room to remove the generator without disconnecting the P/S pump hoses. There's even enough room to do it with the Chevy generator. You'll want to loosen the clamp on the inlet hose to the pump, but it can be done.
Also, that 57 Chevy generator will fit just fine. It's about an inch longer so you need a spacer for the rear bolt. If your original armature dies like mine did, the 57 Chevy generators are a lot easier to find.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 6:34pm
Not sure what's wrong with mine, I found a good guide to testing generators, but I suspect even if it's just a new set of brushes, I need to take it off the tractor to service.
This page was generated in 0.678 seconds.
