D 15 front axle
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 front axle
    Posted: 02 Aug 2020 at 3:00pm
Have a pivot pin support bushing on the way . Anyone replaced one lately ? Have the front end rolled away so I could pull the engine . Any advice is much appreciated . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 7:44pm
just measure the two diameters and find a bushing that fits...
the 'fun' for me was the EGG shaped hole...cleaned it good ,mixed up a tube of JBWeld, mushed bushing in and left for 3 days( NOT in a hurry ).
When reassembling , be sure to use new lockwashers on the 2 bolts that hold the rearpivot bracket thingamabob. When those bolts go 'walkabout' you're in for some 'fun' !!!!
reminds me I should chek them again... at least once a year.....
Jay
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 10:50pm
I get my local fab shop to make up a new pin and weld it to the axle.  They also match up a bushing and fit it in the casting as well.  They also weld up at back of the wishbone to remove any excess wear.
Done it to many of my tractors - they will outlive me for sure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 5:03am
Thanks guys . Guess I'll know more when I get front pulled out . Rear of the wishbone has a worn out bush in it but agco doesn't show one . Have to find a match I guess . Thanks
Play Farmer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 5:40am
I machined a new pin for mine. Crazy how the old one was worn.
The hole is a little egg shaped but the new pin takes most of the slop out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 5:53am
I don't think Allis engineers ever expected this stuff to be used for 60 or 70 years!
Also the could have added a few more grease fittings to key important moving areas.
We need some pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 11:10am
Yeah I'll take some pics when I get this thing apart and ask my favorite son to post them . It'll never be perfect but I'll be happy to get some of the slop out Thanks
Edited by ACinSC - 03 Aug 2020 at 11:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2020 at 3:00pm
re:
well it didn't wear out in THEIR lifetime ! We're the ones stuck with wornout tires and sloppy stuff.....it'll be perfect for the next 2 generations though !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 7:39am
Here was the one I took out of my D17 Wacko Needless to say it was a little used up.
Edited by Play Farmer - 26 Aug 2020 at 7:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 10:11am
Looks even more worn than my D 15 pin . I put new bushings in both of my pivot point holes . should help some , I guess . Thanks for posting
This page was generated in 1.098 seconds.
