Allis Trailer Plow
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Trailer Plow
    Posted: 26 Jul 2020 at 2:31pm
I have a neighbor who used to work at the Allis plant and has a bunch of equipment that he used to farm with but has since retired. He has a plow that he wants me to have but I have never seen it and he wants the whole COVID thing to settle down before I go over to pick it up. He says it’s a 3-16 Allis trailer plow, says he used to pull it in his heavier ground with his 180. I’ve looked around online and cant find much info as far as a model number. I would guess it has hydraulic lift . I can find a ton of info for two bottom trailer plows and 3 bottom mounted or snap coupler but not much on a 3 bottom trailer, any ideas for a model number?
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:25pm
Depending on its age (since you mentioned a 180 pulling it), a trailer plow will have the same designation or number as a mounted or semi-mounted plow.  For example, a model 84 plow could be mounted, semi-mounted or pull-type.  the 80 is the type of frame (spring trip with adjustable frame width) and the 4 is the number of bottoms. Or you could have a 74 in the same 3 configurations but has shear bolts and adjustable frame width. If its older than the 1960s.... then someone else better jump in here.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 8:50pm
If its older than a  50 series plow, likely it will have curved, individual beams, and likely a ground drive pickup mechanism.  The curved beams kinda look like I beams, or railroad rails, kinda got a curved top...Wink
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2020 at 9:00am
Look in the knowledge base on Plows on top of home page - pix & info. Sounds like a 73 w tail wheel.
I used to be young and stupid, now I am not young anymore.
