CA magneto
CBMike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Topic: CA magneto
    Posted: 19 Jul 2020 at 9:45am
The little grounding post broke off of my magneto. I'm wondering if I need to try and EZ out the broken piece or if I can use one of the screws holding the cover on to ground it. As of right now, my tractor is not running due to needing a new starter so I can't just try it
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 12:38pm
That would be a bolt that goes all the way thru inside an insulted insert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 1:05pm
Dick L,
 If I'm understanding your comment, I'm going to have to disassemble the magneto to get to the bolt from the inside and replace it. Along with making sure the insulating insert is good and in place. Do I have this correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 2:55pm
Originally posted by CBMike CBMike wrote:
Dick L,
Yes sir!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 4:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 4:17pm
Thank you all for the help. It is much appreciated. I just got done watching a video on the rebuild. The young gal made it look easy. Now to find some parts
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 4:57pm
Many magneto parts from the link in the video have very good prices.
You may also want to try www.brillman.com
Edited by WF owner - 19 Jul 2020 at 4:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 8:59pm
Boy, I'm telling you that Creston ought to get ahold of that little gal.  He would never have to rebuild anything again.  She can do it all.  What chou think Creston?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 5:03pm
So I am going to remove my magneto from the tractor, hopefully tomorrow. After noting plug wires,should I remove the cap first and note the position of the rotor and/or look at anything else to help when putting it back on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 5:43pm
yes.. taking the cap off is normally OK depending on what type mag you have... but the GEAR timing has to be right. If you move anything, it can change.. Need to look at the PROCEDURE for setting the GEARS right... also on reinstall on the tractor to set timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 5:45pm
read this BEFORE you pull the MAG so you know what your looking for...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 6:17pm
You are all awesome. Thank you for the information.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 5:58am
Some tips that may help: Take pictures as you go. Mark gears so you can put them back and have them mesh as found. Don't turn the engine while you have the mag off. Bonus: you can use the pictures to post on here!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 7:03am
I put a dot of paint on the beveled or marked (metal gear) tooth. It makes it much easier to see now and if you ever have it apart again.
Grant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 9:18am
OLD CROAK MAGNETO has a large amount of info and advice on their web site. They have worked over a couple of mags for me and I was amazed at how helpful they were with advice and the price was reasonable. They are in Washington state.   Grant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 1:57pm
So, I ended up saying the heck with rebuilding this myself. I, maybe or maybe not could have accomplished the job without screwing it up or struggling with the 2 notoriously troublesome set screws. So I contacted Rudy Calin over in Minnesota. Great guy. He had a rebuilt in stock. After 7 hours travel, I'm happy to report that I have a virtually brand new magneto in and my tractor instantly fires up and runs like a .... new AC!! Thanks everyone for your time and advice.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2020 at 10:17pm
Mike, That procedure rarely ever fails.  It can be a little pricey, and there's transportation costs and time investment, but with it usually comes the opportunity to meet some great people, and stop at a small town diner for cheese curds!
This page was generated in 0.281 seconds.
