Polarizing 6V Generators
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Topic: Polarizing 6V Generators
    Posted: 14 Jul 2020 at 5:12pm
Hi All. A while ago, I was having some generator and some charging issues. Among other things, I read and learned about polarizing the generator. This is done, as I learned, by grounding the field winding on the generator, and then briefly shorting the "Bat" terminal to the "Gen" terminal on the cut out relay until you get a small spark.
I have done this occasionally in the past, but I really don't know when it should be done. For various reasons I have had the batteries in and out of two of my tractors several times recently. I have been polarizing each time I reconnect the batteries, before starting the tractor.
Is this necessary? Can anyone tell me when and how often this should be done?
Thanks
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:00pm
It should not have to be done very often. Last I did my CA I was 20 years ago. Do it only when it’s not charging.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:48pm
YEP... i doubt i have done it once every 10 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 8:04am
It looks like I am overdoing it. I guess as long as it charges properly, I won't worry too much about it. Thanks.
jange01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jange01 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 10:57am
Originally posted by fleeter allis fan fleeter allis fan wrote:
.....I have been polarizing each time I reconnect the batteries, before starting the tractor ....... Is this necessary? Can anyone tell me when and how often this should be done?
Only need polarizing if the generator has lost it's residual magnetism. This will be rare. It is said to do it after a rebuild, or extended times of no battery hooked up. Though I have seen them charge right up after sitting for years on the shelf. That being said, when done properly polarizing will not hurt a generator.
Be aware if the generator is am A circuit or B circuit.  This is how the generators output is controlled by the regulator, regulating the field current. 'A' circuit generators are controlled by the regulator varying the ground to the field. In 'B' circuit generators the regulator applies current to the field, which is internally grounded. Keep in mind many generators have been swapped around over the years.
If all else id OK with the generator and it is not charging, polarizing will usually fix the issue
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 12:45pm
Some good advice on charging issues that was passed on to me was to clean your regulator contacts first.  This is especially useful when the generator has not operated in a long time, meaning neither has the regulator.  A very small bit of oxidation will cause problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 5:11pm
I was told it only needs done, when changing out a gen or reg.  I always forget which terminals to jump, I do it so rarely...  Thank god fer youtube...Wink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 6:09pm
The way I remember it is Boy to Girl but never to Female.  I have to admit I really don't polarize mine.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 9:55pm
Also note that just as the generator requires residual magnetism to BUILD it's initial generation, mechanical regulators ALSO hold residual magnetism, as a side-effect of their (polarized) DC operation.
This doesn't mean they won't operate without residual magnetism, they simply develop it, and as such, the residual field augments the active field in regular operation, and thus, adjustment of the regulator is affected by it's augmentation...
OR IF one reverses polarity on a tractor, the residual magnetism will COUNTERACT the regulator's polepieces (cutout and regulate), so the polepiece of the regulator must be exercised and given time to reverse as well, before one can expect the regulator and generator combination to be stable.
So the short story... if you haven't run it in a LONG time, or you've reversed polarity of the tractor, give it some time to settle in, before attempting to 'dial in' the regulator, and expect to have to bring up the throttle and rap the regulator with a screwdriver handle a few times to 'wake it up'.
