PTO lever Jumping out on 7060
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Topic: PTO lever Jumping out on 7060
    Posted: 27 Aug 2010 at 11:40am
Mowing hay with my 7060 and the PTO lever will jump out of engagement when I raise the mower or sometimes not,this does not happen all the time just when you least expect it.Anyone have an idea what to look for or adjust?
ORANGE FARM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORANGE FARM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 12:59pm
THE STAND BY PRESSURE IS TO LOW. SHOULD BE AROND 750 PSI, OR THE BRACKET THAT HOLD THE CABLE IN THE CAB IS TO WEAK.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 3:01pm
Yup standby is too low.  And sometimes it isnt pulling the PTO valve spool far enough.
jrjuday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 9:33pm
ARE YOU LOW ON HYDRAULIC FLUID?
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 6:07am
No I am not low on Hydraulic oil I am going to change Hydraulic filters and start there.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:20am
adjust the cable a bit, see how it goes then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:45am
It's probably too low of stand-by pressure in the hydraulic system, which is an easy fix for those who have gauges, shims and know-how. In the short term, I'd suggest you tie the lever forward with a tarp strap or wire to prevent the lever from jumping out of place and stopping your PTO causing a plugged condition of your hay cutting equipment. A fix?? no, but a short term improvement.
