D17 Series 4 3 point
meshwack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meshwack Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 4 3 point
    Posted: 07 Jul 2020 at 12:26pm
I have a d17 series 4. 3 point will pick up anything I ask. But will not hold. It starts to bleed off asap. The remotes seem to work fine. I can open my round baler and the gate will hold until I actuate to close. BUt the 3 point arms will not hold.
ANy ideas?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 1:30pm
Put a kit in the hydraulic cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 2:55pm
Follow the hoses/lines that go from the lift cylinders to the lift valve section while standing at the rear of the tractor. That particular lift valve section has a rotary valve on the back of it that has a small tee handle. Tighten that tee valve as tight as you can clockwise with a vise grips. Take a larger diameter punch and strike the end of it and try and turn it again. If it moves at all, this may help your settling problem. Most tractors with that type of valve stack suffer a certain degree of settling. Some are worse than others. That is what the position control lever is for. When functioning correctly, the Position control lever will keep the 3pt from settling down.
This page was generated in 0.258 seconds.
