HELP! 303 Knotter Problem
barnabas_12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Topic: HELP! 303 Knotter Problem
    Posted: 27 Aug 2010 at 8:24am
I bought a 303 baler a few years back - it was stuck but had not done many bales.  As I got things un-stuck, I forgot about the tucker fingers.  During the first tie, it bent up the arm that holds the cam-follower.  Getting that off is easy, but it always gave me trouble - and about once/year it would get bent again.  Earlier this year I had to weld a new pin for the cam follower.  Well, last week they crashed again, only this time the cam itself broke.  A few questions:
1.  Is it possible to find individual parts for this knotter, such as the CAM and the CAM-follower arm?  Will the AGCO dealer be able to order, or perhaps someone on-line.
2.  Will parts from other knotters work?   If I bought a old junk NH or JD baler, will those parts likely interchange?
3.  Is it possible to simply swap out the entire knotter from a JD or NH baler.  I hate to do this because mine has so little wear on it otherwise.  However, it will not tie without the tucker fingers in action.
Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 11:53am
I think Dale Schaffer has the parts you need. He goes as Orangereborn,very nice and honest.I think they are same as NH knotters.  HTH Tracy Martin
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 9:12pm
New Holland knotters are the same
