lift cylinder tear down
WI Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WI Dave Quote  Post ReplyReply Direct Link To This Post Topic: lift cylinder tear down
    Posted: 02 Jul 2020 at 1:59pm
big bore lift cylinder 185 Allis
I am sure it is already on here but I have not used the correct words to find an answer.
How do I get this thing apart?
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 4:15pm
Take off the 90 degree elbow. With the cylinder collapsed you should see a snap ring. Move it into the lower groove in front of it. The ram will them slide out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 4:56pm
Rotate the rod while you pry the snap ring to the smaller diameter groove. Reverse procedure to assemble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WI Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 7:44pm
This looks entertaining.... Pin stuck about 3/8 inch out before I started, don't want to go in or out.
In the middle of moving my shop so it will be a bit before I can tie hard into this for now. No way I am going to get that ring without complete removal of cylinder. I need to change brakes so I will attack this when I tear down for that.
Thanks everyone. I appreciate it.
Edited by WI Dave - 04 Jul 2020 at 6:05am
This page was generated in 0.099 seconds.
