Looking for a little help
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a little help
    Posted: 24 Jun 2020 at 7:17am
I am trying to rebuild a marvel schubler carb on a D-15 series 2 and the small seat in the bottom of the bowl will NOT come out.  I am looking for ideas on how to remove that seat, I have a kit to rebuild it and that is the last obstacle in the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 9:49pm
Why do you want it out?          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 6:11am
Might be one of those 'leave well enough alone' situations.
Assuming the seat is slotted, you'll need a PERFECT fitting screwdriver. test and modify a screwdriver for a firm EXACT fit, both width AND vertical side walls !!!
Then use 50/50 ATF/acetone and soak carb for 1-2-3 days, maybe preheat the seat area(very warm. not 'flashpoint hot' !!.
Securely put carb in big ,steady vice.. tight not Tight...
Attach vicegrips TIGHTLY to the special screwdriver just above the top of the carb
Put good downforce on screwdriver with right hand, use left hand to 'jerk' the vicegrips fast, about 90*.
if, IF it move,add more 50/50 mix,relax take a break,  then slowly go 1/2 turn out, 1/4 turn in, repeat a zillion times, and you've won.
This is truly a ONE CHANCE event...you NEED patience,the correct tools and technique to suceed....if you don't have all 3.....sigh..you'll need another carb body.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2020 at 6:30am
I haven't tried it myself yet, but have seen some postings of boiling the body in water for a time having success in freeing jets/brass parts in a carb.
