D 15 valve cover
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 valve cover
    Posted: 22 Jun 2020 at 1:06pm
Getting ready to put mine back on . Have a new gasket and 4 rubber grommets . My metal washers are mismatched and a couple are concave . I'm thinking someone overtightened the nuts causing this ? Sound right to you fellas ? Also wonder what the torque spec should be ? Can't find it in my book . Thanks !!
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 6:02pm
I doubt you will find a torque. Its a feel thing. You are compressing a thick gasket. Tighten down enough to squeeze the gasket some, if it seeps, tighten a bit more. This can be done several times over the life of the gasket if you don't get carried away tightening the first time. That's my method, others may do different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 7:49pm
Yeah Jim it's a very thick gasket . I'll just snug it up and see how it goes . May try 10 lbs . That's my torque wrench lowest setting . Thank you !!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 8:37pm
Don't even use a torque wrench.  Make sure your valve cover is perfectly straight before you put it on.  Just put a slight bit of pressure on each nut and use the tractor normally.  Tighten them down until it does not weep any more with use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2020 at 4:28am
Thanks Myron . Valve cover looks straight to me . Probably finish up today and keep an eye on it .
Edited by ACinSC - 27 Jun 2020 at 5:58am
This page was generated in 1.287 seconds.
