D17 lift capacity? |
Post Reply ![]() |
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1172 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jun 2020 at 6:00pm |
How much can a rear hay Spike on a d-17 lift weight Wise?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21829 |
Depends how close it is to the tractor, how much pressure your hydraulic pump is making and how many front end weights you have. A series 4 has more lifting power than a series 3. A series 3 has more lifting power than an older D-17 model. A bale spear 6 inches farther away than it should/could be makes a BIG difference on what can be picked up.
I will guarantee a homemade snap-coupler bale spear that almost rubs the hay bale against the PTO shaft will pick up far more than any manufactured bale spear connected to an add-on 3-point hitch !!!
Edited by DrAllis - 19 Jun 2020 at 6:27pm |
Ok, thanks
So now I'm on the lookout for a solid snap coupler bale spear! |
What size of bale do you desire to pick up??
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5086 |
I have one of those HD semi plow hitches that would be a good starting point for a homemade bale snap coupler bale spear. Where in Ohio are you located? I'll be heading north of Columbus sometime soon.
Edited by PaulB - 20 Jun 2020 at 11:41am |
Probably between 600-1000 lbs
Northeast Ohio |
I had a customer (40 yrs ago) doing 1500 lb+ bales on an old D-17 diesel. I had his pump cranked up to 4,000 psi and he made a close coupled snap-coupler spear.
Does anyone have pictures of the snap coupler hay spear connected so I can make one?
Post Reply ![]() |
