B Oil Breather Cap Stuck |
Post Reply ![]() |
MotorCityBear ![]() Bronze Level ![]() Joined: 27 Jul 2013 Location: N. E. Georgia Points: 84 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jun 2020 at 9:11pm |
1953 B that has been “neglected” a bit while life got in the way. Finally getting to it.
Before cleaning the carb out, which it needs, I drained the engine oil and installed a new oil filter. Went to add the new oil and the breather cap appears to be frozen in place. I tried WD-40, a hammer, small oil filter wrench etc. but this thing is not budging. I am thinking I will need to remove the valve cover and hammer the cap from the underside. Do you guys have any other suggestions for getting the breather cap freed up?
Rob
1953 AC B Kubota L3901 Blairsville, GA |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87223 |
I had one like that... used 16 inch adjustable pipe pliers..... didnt look to good when it finally came off.
kinda what I am thinking. I guess I should order the new breather cap now, since it may not survive the “removal process.”
Rob
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8448 |
Rob,
Yes it is probably rusted in place. Removing the valve cover and trying to tap it out upside down sounds like it might work too! Post some pictures. Regards, Chris
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
Use a strap wrench on it. Turn it back and forth as much as possible to loosen things up. if that fails, twist it off any way you can and replace it.
Post Reply ![]() |
