190xt cozy cab info
6080fwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Topic: 190xt cozy cab info
    Posted: 16 Jun 2020 at 3:34pm
I just bought a 1966 190xt with the upgraded axles and the fan doesn't work in the cab. wondering how to get to it, wiring and fuses look ok and have power.
Also wondering if anyone knows where to get a cab air filter?
thanks
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:45pm
Probably have to remove the roof to get to the blower.
I would get the part number from the filter for a start.
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:49pm
Have you checked for mud daubers nests in the blower? I had to clean them out in order to get mine to work. Next make sure there is 12 volts on the out going side of the switch and it is getting to the fan motor.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:00pm
Were different models of those cabs so may be different as far as filter and fan access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:47pm
I looked at the roof 4 bolts on 4 corners and 2 bolted hooks.... do they come out too? the filter is long gone....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:50pm
it looks like birds were nesting there with the filter gone... if anyone has a filter number it would be awesome to get it. I think the cab was ahead of its time....
are the rubber insulators supposed to go between the cab and the tractor? they are installed underneath the tractor deck....
thanks everyone for your help!
the new stuff is too electronic and expensive!
Moneypit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:52pm
The cozy cab on a 190xt I had you took the blower motor out from the inside and ap air should have something for blower motor if you need a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:57pm
my blower motor is right above the left side door. how did you get yours out? I don't see any screws there...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 11:01pm
Mine was right above windshield definitely different style of cabs sorry can't help on that
Bob J (Wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J (Wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 7:47am
I have a cozy cab off of my 200 that I am not using, it is for sale
Make an offer.
It should fit a 190.
