7020 trans/hydraulic fluid
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 trans/hydraulic fluid
    Posted: 16 Jun 2020 at 9:11am
I am going to be changing all the fluids on my 7020 and wondering what fluids I should use. anyone have the oil capacity list for one of these? and yes Im using all AGCO filters   Thanks
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 9:45am
"All Fluids". . . .boy, that's a can of worms, to ask what to use that is.
Since you're going all Agco filters, you could get your fluids there too.
Engine oil? Start debate here:_____________ Rotella, no Rotella is junk, Mobil Delvac, nope, Walmart....
Honestly, if you've had good luck, or no bad luck, with a product in the past, if this isn't your first tractor ever, just stick with what you know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:26am
I am not concerned about engine oil, more so how much and what the book says to run in the trans and hydraulics. I would go with all agco fluids if the price was a bit more reasonable and the dealer wasnt over a 3 hour round trip so I had the filters shipped
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 10:37am
OK, well then that's not "all fluids".     And I just started with engine oil as the example, because it a rather....uh.....notorious discussion starter on the forum!
Same argument though, what one guy uses another trashes. What brand do you use in your 190? What spec does it meet for Universal oil? Pretty much every modern universal oil meets the Allis spec for those tractors. I've used Traveler from tractor supply, people will trash it, then in the same thread a few posts later, someone is buying their oil from Walmart. This year, I bought a 55 gal drum of Kubota universal oil because it was on sale.
Good luck with the tractor, whatever you choose.
P.S. My Allis is a 7045
Edited by Tbone95 - 16 Jun 2020 at 10:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:24pm
a good quality Universal Tractor Fluid or Universal Hydraulic Fluid is what you want. The AC spec is 821... CASE might call it Hy TRANS... others have their spec.. Aftermarket Companies normally make a GOOD Oil that meets several specs.. They might also make a CHEAP oil that meets very few specs... All the 5 gallon buckets have a list of SPECS on the back that they meet... It dont matter if you get it at Wal Mart, Auto Zone, NAPA, or the local FARM STORE.... as long as it meets the SPECS on the back... AC does not make oil.. Wal Mart does not make oil.. CASE does not make oil...  You will get SHELL, AMACO, EXON or something like WARREN who is an aftermaket supplier for a DOZEN different small places ( Farm Store, NAPA, etc)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:26pm
Here is what the back of ONE bucket of HYDRAULIC oil looks like SPEC WISE...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 7:33pm
PUR fLO 303,, Dont let anyone chit ya, and dont use the cheap stuff, it will burn it up
Edited by DougG - 16 Jun 2020 at 7:35pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 8:02pm
Here in ND I used Mobil or Cenex, both had good hyd oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 9:31pm
well that's great and all but about as helpful as a rock is hard, does anyone have a copy of how much fluid goes into each spot and where to fill it. my tractor has about a 2 inch plug with a dipstick on the floor under the seat and another plug with what looks like possibly could have had a dipstick attached so far about the only thing I could figure out was how to change the powershift filter but are there separate filters for the main hydraulics? if so I cant find them if anyone knows where to find some good original manuals that would help a ton. thanks
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 9:34pm
Is cen pe co good hydraulic fluid for 7000 series? Label says its compatible to allis 821.
Thanks cory
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 10:19pm
Thanks cory
Been using CenPeCo hydraulic oil for years. No issues.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2020 at 10:20pm
This is from a maroon belly 7060 manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 6:30am
So....It was very helpful then!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 8:08am
Youngorange2000 I sent you a pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 8:19pm
I have a like new owners manual if you need one, pm me for details.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2020 at 9:17pm
Capacities are shown in the manual.  I have had good luck finding original manuals on ebay.  Once you have the manual, you will have everything you need to know about your tractor.
