D14 trans noise
nx08634 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nx08634 Quote  Post ReplyReply Direct Link To This Post Topic: D14 trans noise
    Posted: 14 Jun 2020 at 10:28pm
So I have a D14 that starting making noise in the transmission. If I push the clutch in it quits.  On the high side it isn't very noticeable, but on the low side it really gets loud.  Can anyone give me some direction as to what's going on? I know I'm going to have to split the tractor that's a given but I'm not sure what to look for. I went through the engine on this tractor about 16 years ago with a total overhaul. That was pretty straight forward engine stuff but not sure what I'm getting into here. Also is there a good source for a shop manual?
Thanks in advance for your input & help.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 5:47am
Shift trans into any gear and set the brakes. Leave the hand clutch in NEUTRAL. Is the noise still there when you take your foot off the clutch pedal ??
