PD/TA ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: PD/TA ?
    Posted: 31 May 2020 at 8:24pm
Are the power directors in Allis tractors  similar to the torque amplifiers in IH tractors ? I realize the ta's don't have a neutral position, but otherwise do they do the same function ?
Seems like the ta's get repaired/replaced/"locked-up" somewhat often .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:59pm
Nothing a like. PD IS two sets of wet clutches with gear reduction ahead of them.
TA is a planetary with a spray clutch.        MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:07pm
Power directors were far more reliable than the TAs!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 6:20am
TA = TroubleAhead. If a Torque Amplifier isn't broke, it soon will be. Many TAs will coast downhill. A Power-Director is a positive drive in both ranges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 7:37am
There was a reason for the saying "every time you throw the T/A handle, put a dollar in a coffee can cuz yer gonna need it to fix it sooner than later".
Still plenty of them in use, albeit locked in low so the tractor can still be used without the major expense for tear down/rebuild.
Have known some to still run hard for years after locking them in low side, after they had them rebuilt once or twice.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 7:41am
Agreed. While in college, the Farmer I helped during spring plantings had only one thing to say about his IH 806 on the disk, “Put it in gear & LEAVE the TA alone!”
Technically, that’s two things :)
AC’s PD took punishment- ie roto baler!
Edited by AC7060IL - 01 Jun 2020 at 7:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2020 at 5:12pm
That brings up another question, were the WD/D series a "wet" or "dry" clutch set-up (P/D) ??
Mack made a statement about "wet clutches",  but I assumed this was for the "hundred" series ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 11:44am
Really? Apparently you haven't read any post in the past about WD Through D series hand clutches. The answer is there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 12:21pm
WD & WD45 had a “2 clutch power control” (foot & hand clutches). The foot clutch operated an engine dry clutch that engaged/disengaged everthing(trans/pto/hydraulics). Their hand controlled clutch ran in oil & only engaged/disengaged trans, allowing pto& hydraulics to continue operation.
The D series’ had a similar setup except it’s hand operated clutch became the 2 speed “power director” (high & low “stick PD”). It too ran in oil.
The 100 series (not 160)also carried the 2 speed PD which also ran in oil. But the 200,One-Ninety,One-Eighty, & 185 PD was hydraulically operated vs the hand “stick” control on the One-Seventy,170,175’s PD.
Edited by AC7060IL - 04 Jun 2020 at 9:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 6:11pm
Thanks for your AWESOME reply Steve WinkWink !!
To 7060, a sincere thanks and we ran a WD, D 17,15,19 before the 180 and 190.
This page was generated in 0.431 seconds.
