Smoking Like A Locomotive ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Smoking Like A Locomotive ??
    Posted: 20 May 2020 at 5:55pm
The 7050 post got me thinking about the "black smoke" coming out of Nick's machine, but we run a '68 190 XT diesel that will/does "roll-the coal" under load and always has since dad bought it; he's the second owner and had less than 1000 hours on it when he bought it. It's had a turbo replacement 7 years ago, no pump/injector work though. Is this just the nature-of-the-beast with the 301 ? Seems like years ago we had a neighbor that ran 210's and they could leave a descent plume also Wink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 6:11pm
black smoke is excess fuel... may be common during acceleration... If it does it under load CONSTANTLY, the pump is set too high for the turbo / motor displacement..
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 6:25pm
This pump is all original, every wire through bolt/nut heads are still intact Wink
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 6:29pm
Black smoke is unburned fuel. Is he running a premium #2 diesel or is he using truck stop style #2 fuel. Premium #2 fuel is the fuel he should be using. It has additives in it to stop the incomplete combustion. It has a higher cetain rating than truck stop fuel. If he is using premium fuel, his pump has a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 6:35pm
We only run fuel from the local "co-op", always have since the purchase of this tractor; first diesel on the farm Smile. The F2 will leave a pretty good plume also (433) and has had the pump rebuilt and injectors tested. A neighbors WHITE 7600 combine will out-smoke the 190 though LOL !!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 7:00pm
Worn or dirty injectors, lack of turbo boost or bad turbo seals bad could cause excess smoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:17am
A-C's turbocharged engines were not designed to be loaded under about 1700 RPM, because the turbocharger isn't able to deliver enough air for the fuel setting. Keep the speed up and you won't see much if any of the heavy black smoke. It's the design and nature of the beast.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:30am
It all depends on what your definition of ‘rolling coal’ looks like.
I remember years ago, we had a Uni-system with a Allis engine and always left a bit of a trail combining, and when it was on the forage chopper. Tractors were all IH, and the 856, and 1086 would leave a trail plowing, or when on the chopper. The 826 w/German diesel would very seldom.
Now if it blacking out the sun, like at a tractor pull that’s a different issue.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:37am
the 7020 i had had the 301 with factory turbo and injection pump on factory setting it would leave a steady trail of visable black smoke with decent load on it at pto speed! my dads 1971 185 has done this under load from new. i was told its a normal thing for these old machines.
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 8:07am
But, your 7020 under 1700 RPM was HEAVY smoke......which is under the turbo spool up speed.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 8:46am
That doesn't really mean it's still set a spec. That always gives owners a false sense or originality. A dealer mechanic who just did some tweaking, could put on a new seal wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 9:07am
You can argue that " it was always that way"... but the moral to the story is that BLACK SMOKE means your wasting fuel..  raw fuel is going thru the muffler........ Whether its a bad turbo ( low air flow) , too slow of rpm ( low air flow), worn injectors ( excess fuel) or the pump was set too high ( excess fuel)....the result is the same... BLACK SMOKE due to lack of air or excess fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 6:10pm
That "could" be the case . Dad acquired this machine at a local A/C dealer in 1983 after it had set on the lot for 2 years. The original owner brought it in to the dealer to repair the tranny/rear end. After the owner got the $5500 invoice to "update the tranny, told the dealer to keep it Stern Smile. The turbo has been replaced, and to the others, my definition of "smoke" is  being able to turn around on the end row and be able to see your way back without looking at the ground (provided no wind) LOL !!
I will add that after the turbo replacement, it was dyno'd at 95 HP Embarrassed
Edited by FREEDGUY - 21 May 2020 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 7:06pm
The thing many don't understand about diesel injection systems, is the torque curve come in to play here. When an engine is running at rated speed(say 2200 for a 190XT), the fuel is cut back some on a fuel system, mainly because the engine can't get enough air for the amount of fuel capable of being injected, and/or it's cut back to achieve the desired lower hp level.  Now torque rise is the engine's ability to deliver more torque as it's lugged down below the rated rpm(2200), which in turn helps it maintain that rated speed. Peak torque is usually around 1500 rpm, so as it pulls down the fuel injection system continues to inject a higher quantity of fuel, plus the engine has more time to catch it's breath between events. So the Roosa pump usually delivers it's maximum fuel at idle speed, throttle wide open. Now, you are idling at 700, and slam the throttle wide open, the pump is now pumping it's highest amount, but yet you are way below the turbo working range, so it smokes black until the turbo builds boost to clean up the smoke by burning the fuel. Plus as it increases speed, it's going up through the torque curve, trying to get to high idle of 2450 with no load. Clear as mud? lol!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2020 at 9:47pm
The issue of smoke was a continuing engineering exercise with AC Harvey.  The engines were designed as low RPM engines, naturally aspirated at hp levels  much lower than later hp levels  that rose to levels never envisioned by the original engineers.  One of the highest hp/CI engine was the 4.33I.  The engine on the F2 was set at 95 hp and the 'orange' engines did smoke.  The last black engines with higher compression and the smaller hole  bosch injectors tips were almost smoke free at the same hp. The same addition of these injectors on the last 185's were smoke free as well.  Of course no one was satisfied at stock settings.  I questioned two of the engineers about the lack of cam shaft profile experimentation and why the much lower than competition turbo boost levels which would have eliminated the skywriting diesels.  The answer was no one wanted to buck the old timer engineers who got burnt on the D262T cam change and that just downsizing the A/R on the exhaust was good enough. Plus they didn't have the money, plus the commonality of parts through various hp levels was an economy thing. Finally ,  when an AC customer got a new tractor that didn't smoke - he felt like he had a tractor that needed more fuel....
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 5:55pm
 LOL!!! The "sky writing" comment is basically what we've experienced since 1983 LOLLOL. Thanks for the reply !! Yes, our F2 does  leave a plume of black, but not  like the XT Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 10:13pm
You definitely have an issue. My XT barely smokes even under the load of a sled going down the track. Certainly not rolling the coal. In the field bailing, discing, cutting hay, it is pretty clean. The pump was rebuilt by Ed so it’s clean “smoke” I attribute to his knowledge and skill. You may want to have your injectors and pump checked out.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 11:25pm
When there's insufficient oxygen in the woodburner, you get smoke and creosote buildup inside the firebox and chimney, low heat output, and very poor draught.  That creosote is fuel energy that has been dumped out the exhaust, and thrown away, coating surfaces and making a mess.
When there's insufficient oxygen in an internal combustion engine, you get unburned fuel going out the tailpipe, turning into all forms of soot and goo, and wasted fuel-energy going to waste.
Diesels will smoke for a little bit before they reach proper chamber temperatures, and brief moment after cracking the throttle, before they build boost.  IF it's smoking, add oxygen, or reduce fuel.  It's not the injection pump's job to fill the cylinders to use fuel pressure to hydraulically force the pistons down, it's supposed to actually burn.
Fools program their EMCs to overfuel.  Competition performance engines smoke for the timeperiod when they're in a state of underboost... which is inevitable, as they're optimized for max output and high-RPM operation, and thus, injector sizing does NOT have the ability to 'meter small'... they're not a 'wide bandwidth' metering setup, they have no choice but to sacrifice efficiency to be able to 'peak' at the high end.  They tear the engine down after a few runs.  A field engine does not have benefit of that rigorous of a maintenance plan, nor does it operate sensibly with a 'full-tilt-only' powerband philosophy.
Edited by DaveKamp - 22 May 2020 at 11:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:23am
Hasn't anyone realized trying to logically explain something for gassey is like doing card tricks for a dog Wacko
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:41am
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:54am
My 78 (orange engine) F2 looks like an N6 going through the field...or down the road. Not going to spend the money to clean it up....it sips fuel so who cares?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 7:02pm
Funny when I was a youngster- seemed the common question on an Allis was - how much is she turned up -? Was working for a guy that had a One Eighty that had the pump played with, didnt smoke that much but had a lope at idle that was awesome,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 7:14pm
The story goes something like this: During the summer months of I suppose 1979, there was filming done of the new Gleaner N-6 on the wheat run. The product of this filming was then inserted into the Dealer Open house movie for the winter 1980. Some top A-C execs saw the video of the new "N-6's" going thru the fields with a pretty heavy trail of black smoke and there was a phone call made to the Harvey Engine division to clean that smoke up. By the 1981 build season, Bosch injectors were being used in those engines and that was the first step in reducing smoke. By 1982, we then had the M-100 American Bosch injection pumps to go with the Bosch injectors. They were still never as clean as a good IH-66/86 series, but were better for sure.
This page was generated in 0.434 seconds.
