8010 low remote flow
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Topic: 8010 low remote flow
    Posted: 13 May 2020 at 6:24pm
Remotes work very slow. Flow adjusted to fast setting. Good pressure
at remotes 24-2500 psi. Have not checked standby pressure yet. All other hydraulics work good. Changed filters also. Any ideas?
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 7:58pm
Check the wear on your linkages turn them out one or two turns and see if that helps, you may not be able to put it into float if it’s wore too much, but this should get the flow to full
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:22pm
With the engine OFF, pull back on both remote levers. They should lock into the raise detent, which should give full flow. If they don't detent, there is a stop bolt for each lever inside the console that you might be able to coax a little more stroke out of each lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:51pm
Forgot to mention,i took cables loose at valvestack, still slow flow at full stroke. It has 3 remotes all have low flow
Edited by K bockting - 13 May 2020 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:11pm
Try the flow controls 1/4 turn different and then another 1/4 turn more. They are different than 7000 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:35pm
I did try that slows them down
Set at 2 oclock position from front of
stack for best flow
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:43pm
Also have changed couplers
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 11:23pm
Sounds like you have done everything?
Is there any leaks on the side of the tractor?
Check all hoses...any kinks, pinhole leaks, etc.   Could be somewhere you're not looking.    Front to back.
Suction hose clamps? (is there any?)
Pump seals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 5:45am
Used agco filters can they be installed backwards? Changed many times never an issue. Did have this problem on 2 of the 3 remotes before filter change. Will check compensator when get a chance
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:28am
I'm thinking something on squash plate broke and is blocking squash plate from going all the way.            MACk
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 8:48pm
Stand by press was low set to 500
Did help somewhat still thinking other issues will give it a try
Thanks for responses
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 9:44pm
Flow controls on 8000 series are max flow when the long side of the roll pin is at 9 o'clock when standing behind the tractor. This is different than 7000 series. When long side of roll pin is at 3 o'clock it is fully slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 6:51am
Will check it out thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 6:57am
If you had access to a hydraulic flow meter, the max flow out one remote is 17 GPM. If you don't have access to a flow meter, then I guess I'd be dropping out the pump and see if the swash plate spring is broken or something else inside the pump is amiss. I have seen pumps worn out where they spin against the end plate. While this is rare, a lot of hrs of hydraulic use with dirty oil accelerates that wear.
