Sealing 8000 series cab |
Post Reply ![]() |
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
![]() ![]() ![]() ![]() ![]() Posted: 10 May 2020 at 3:55pm |
Got a 8030 and 8050 I struggle to make the top of either 100% water tight. How do other folks go about it. I thought about using the caulk on a roll they use to seal seams on grain bins.
Daehler ![]() Orange Level Access ![]() Joined: 23 Nov 2010 Location: Lexington MO Points: 1159 |
Silicone the bolts. Thats stopped it on one of my 8000s. Haven't done the others. Plus a new seal that goes under the top helps too.
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7496 |
AGCO has a gasket kit and rubber washers for the bolt. Haven't had any problems with the one I put on my 6080.
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
Buy rubber washers for the bolts or make your own with inner tube and a hole punch.
Post Reply ![]() |
