1975 AC 200
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 1975 AC 200
    Posted: 10 May 2020 at 1:17pm
What is the pulley size on alternator and what is the tooth count on the tach drive, and inside alternator. Have a feeling the hour meter seems to be rolling over too fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 2:56pm
Kits for that on Ebay
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 5:23pm
I have been down that road and I can’t remember what the tooth count should be. I did go to harbor freight and buy a tachometer that came with reflective tape I put on the pto shaft and verified my reading was correct. The tach wasn’t all that expensive and I use it to verify all of my tractors.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 5:45pm
DJS tractor parts catalog has all the information that you should need.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 12:25pm
Teeth are 12 and 45.
Pulley is 3.125", #70256332
AC also used 1/2"belt dual groove , .670 bores;
3.25", #70254832.
3.50", #70260105.
3.50", #70262156.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 6:27pm
Just out of curiosity, what does the tach needle show? We got a complete rear assembly for our 190 alternator from a local starter/alternator shop with "AGCO" numbers, they were for a MASSEY tach Confused. The needle would peg-out at 3/4 throttle Ouch. The "MASSEY" big gear is 48 teeth.
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 5:54pm
If anyone ever runs into trouble with the tachometer itself, I had great luck sending them to a gentleman in Florida named Haim Zeevi. He rebuilds them. He is very professional and does excellent work. Does work for show cars and tractors as well so is very particular. He also rebuilds and reworks cables, and has other miscellaneous items to repair tachs and speedometers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 6:11pm
The way those tachometers were designed to work was 1 hr was logged if the engine was ran near full throttle for an hour (rated speed 2,200 ). So, there's no way it can rack up more hrs unless the tachometer needle is buried at half throttle.
