1950 WD
Ewhitford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Topic: 1950 WD
    Posted: 01 May 2020 at 10:55am
I have a 1950 WD with the delco remy distributor could anyone tell me what the firing order is for that.  I need to double check mine. I am unable to find it in my book unless I am over lookinig it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 11:09am
1-2-4-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 11:33am
1-2-3-4 is that from the front of the tractor going to the back I asume ? and how about on the distributor cab.  It does have a 1 by one of the post on the inside of the cab.  I assume that #1 cylinder goes there maybe ? but looking at the cap from the top on the distributor. is 2-3-4 clock wise or counter clock wise around the cap or how should the wires be placed on the cap.
Thank you.
Edited by Ewhitford - 01 May 2020 at 11:34am
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 11:38am
As Dr. Allis says, they should be placed on the cap 1243.  The rotor turns clockwise as you look at it from the top.  #1 cylinder is at the front of the tractor.  if the distributor is installed correctly the terminal toward the front and toward the block is usually #1 and in a clockwise fashion you then go 243.  However, you can install the distributor so that any spot is timed to #1 and then place the wires accordingly starting at  #1.  So, just need to check that the rotor is pointing to #1 when #1 cylinder is at TDC at thye beginnig of the power stroke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ewhitford Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 1:03pm
Ok thank you folks. The wires are good.  Think I have a electrical issue somewhere.  I have no spark coming out of the coil. Brand new coil. As I thought the other coil went bad.  No I did not check it.  When I got the coil originally the spark produced was getting weak. So figured my coil went.  So now I need sugestions on the no spark.  I have a new wiring harness in it. I also replaced the starting switch with another one. The one I had in there fell apart.
Thank you.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 1:36pm
Have you checked the points & condenser ?  Or checked for power to the system ?
