Wc/wf fenders
T Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Topic: Wc/wf fenders
    Posted: 25 Apr 2020 at 12:17pm
Was wandering if anyone out there was reproducing unstreamlined rear fenders? I can just use the rolled bands and build what I have if need be.
Thanks for any info.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 1:47pm
I assume you are talking about fenders for an unstyled WF or WC?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 3:59pm
I made a pair of fenders for a 38 unstyled WF from unstyled WC fenders.  You must use the inner skirt from the WF fender or fab a new one. Also the WC fender is longer and must be cut down.  I could not find the correct "high top" rivets to fasten to the brackets so I made some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 7:28pm
Correct the non-"streamlined" is what I'm inquiring about. Was hoping someone out ther was rolling a few reproduction ones.
If I cant find that I guess I'll sacrifice some wc fenders.
Just curious b26240, how or what did u use for your rivets? I hadn't got quite that far in my search.
Btw it is a top notch restoration I plan. Already in way too deep to quit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 10:46pm
I have a brand new pair if interested. $950 for the pair.  Sand em', prime em', paint em'.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 6:20am
T Hunter;    Mild steel whatever size the head was, been at least 10 years put it in the collet chuck on the lathe ground a hss tool bit to form cut the raidius turn the body to size and part off.  I do remember heating the end red hot and peening with the head resting on a block of wood to not damage (flatten) it.
