Paint
Sparks farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparks farm Quote  Post ReplyReply Direct Link To This Post Topic: Paint
    Posted: 22 Apr 2020 at 11:03am
I have a wagon frame that i am going to paint, does any body know about how much paint i will need to paint a 4 wheel wagon frame. It is $180 for a gallon at my local PPG store but i dont think i need that much.
Dandan111 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dandan111 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 11:18am
Jeez what kind of paint you looking at?
Are you spraying a metal frame?
That's show paint price I'd say.
Buy machinery paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparks farm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 11:20am
That was for acrylic enamel paint. What brand equipment paint do you recommend that will last a good time and not fade quickly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparks farm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 11:21am
Sorry i forgot, Yes it is a metal frame
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dandan111 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 11:57am
I bought cheap latex barn and maintenance paint for my metal building I’ve been covering rusty
siding and wood. Don’t know about
fade but it looks 10x better than rust.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 4:58pm
Hello Sparks    2 qts  Bite the bullet will last loong time / machinery paint will turn dull pink
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 5:34pm
I did an AC running gear last fall. It tool just about a quart (for just the running gear).
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 5:42pm
I can't see it taking more than a quart if you brushed it on. I buy 'Rustoleum' gloss black, goes on very nics, hardens fast. Use DollarTree brushes..
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 5:47pm
NAPA can order you a case of Krylon 1820 spray cans.  Good match for AC orange and stands up well.  I painted a whole RC with the spray cans in 2003 and it still looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 5:49pm
I used some Chevy engine orange (acrylic enamel) that I had on the shelf. I reuced it slightly and added hardener. It sprayed very well with a $10 HF HVLP gun.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:20pm
I have been buying enamel by the gallon. I get a pint of Valspar hardener from Amazon and buy a quart of VM&P thinner from the box stores. The ration is 8-1-1. Eight parts paint. You can spray it at this mixture or what works well also is to get a 4 inch roller and tray. Get the white foam 4 inch rollers. Line the tray with aluminum foil. I buy brushes at Harbor Freight for a buck each. When finished you will have zero cleanup.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
