Precleaner bowl on a 7060
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Topic: Precleaner bowl on a 7060
    Posted: 20 Apr 2020 at 6:54am
The precleaner bowl cracked on the 7060 I have ordered one from suppliers and they are to small. This has a 10-1/2 base  and the others are to small at the base,. I am sure this is a factory install any ideas,,,
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 6:58am
DJS tractor parts sells that pre cleaner bowl. # AB-339D $16
Replacement number for 70651270
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 2:12pm
DJS does not, it is to small, he said there is only 3 sizes, so it is the size everyone has also.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 2:32pm
You might try Donaldson Manufacturing.  They're the ones that actually make the plastic bowls.  I got one from them but had to go through one of their local dealers.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 3:01pm
Got mine from Shoup
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 9:57pm
Cdreb, what is size of intake pipe pre cleaner is on? Most 7000 series have 4" inlet pipe. IF its 4" try ordering AGCO 70651270 or online from ASAP #157282 @ $16.49. Itll be 10.5" D @ top, 3" tall and inner diam of cone is 5 9/16". Fits my 200, 7000 and freinds 7050. Years back was around some on construction equip that were 5" & 6". Try heavy equip dealers for them, they're scarce.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 10:36pm
The big ones weren't from Donaldson and was 30 to 45 years ago on Euclid or Wabco equip. With Detroit or Cummins industrial power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 11:03pm
i took one off an Case/IHcombine and it fit my 7080.
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2020 at 11:31pm
Got mine from Agco.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:46am
I will measure it tonite, I know the base, not the top is 10-1/2"  that is what is misleading when I ordered it the first time....
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 8:05am
That size bowl is used on may applications, from 190XT's to 4020's, to 7060's, various Case tractors, IH's etc, etc. I got mine for the 210 from my Agco dealer buddy, and it was the 70651270. I've taken the air stack off the 210 now, so the nearly new bowl got put on the 7040.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 8:19am
get it from agco cheap ones turn yellow faster from sun
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 9:40am
Wild idea it’s an Allis call your Agco dealer
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 11:58am
I personally would replace the whole precleaner assembly with the standard one from another tractor. I have never liked the looks of those large bowls. 7060s are the only tractor I've ever seen them on also.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 5:25pm
I just looked up this guys part # on the Agco Site, came up with 7026935 ??  I've not seen a # with a "706" prefix ??
Edited by FREEDGUY - 21 Apr 2020 at 5:27pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:12pm
If all it’s cracked pieces are available, you might try super glueing it back together. About 5+ yrs ago I glued one of mine & it’s still good. It’s used on a regular basis too.
Edited by AC7060IL - 21 Apr 2020 at 6:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:39pm
My apologies to InjectorEd , I browsed into the XT parts and sure enough, there was a "706"prefix # for the OP's bowl Embarrassed. No disrespect intended Wink. I just had never run across the 706 prefix until tonight Smile. Does anyone have a reason for the 702/706 part # variation ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 6:59pm
this should be what he has. Its larger than most models 190XT,220,7030,7050 ECT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2020 at 6:47am
That's it, in the pic, I did measure it on the intake tube it is 4". I called the Masseys dealership to order one I hope it is right.  Thanks for the help guys, mine is beyond repair, I really didn't want to change it out, with the hassle of chasing down parts,,
This page was generated in 0.602 seconds.
