I60 diesel
Dieselherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Topic: I60 diesel
    Posted: 12 Apr 2020 at 8:27am
I have a I60 diesel same as D15. I think injection timing is off. Where is the timing marks on the flywheel and where is the pot/hole to view it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 9:07am
Unless someone has had the front end of the engine apart and changed the gear teeth location, that isn't the problem. The RoosaMaster injection pump can be rotated back and forth a few degrees each way to vary the timing some. Generally, the pumps are located near the center of the adjustment slots. There is supposed to be a timing pin dowel attached to the rear engine plate on the left side. Unscrew the timing pin dowel, turn it around and stick it in the same hole and put your finger against it, pushing it against the flywheel. Have someone slowly turn the engine over until the timing pin dowel falls into a hole in the flywheel. At this point the timing marks inside the window of the injection pump should be aligned.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:05pm
Basically what I've said in this situation, is time it as Dr says, with pin in flywheel. If pump marks won't line up, turn it one turn, pin it again. If pump marks still won't line up, the drive gear is either off a tooth or several, or it has slipped in the shaft. I have had these do that before when trying to run the pump in old crappy fuel. Amazingly it didn't totally seize the pump, but did damage the pump enough to need a replacement head and rotor. This pump was nasty when I got it for rebuild, so slipping is not out of the question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 12:35pm
Does anyone have a pic they could post for this gentleman? He is having great difficulty figuring out where the engine's timing marks/pin hole are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 1:18pm
Pin and pin hole are on the left side of the tractor underneath the steering shaft as it comes thru the bellhousing, as I remember an old D-17 from 40+ yrs ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 1:25pm
Is he sure that the pump driveshaft isn't 180 degrees off ??    DOT to DOT on the driveshaft ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2020 at 2:33pm
I sure think he got them right, but this one has been a head scratcher, plus I'm not there to look at it.
This page was generated in 0.328 seconds.
