M&W Piston/Sleeve Kits
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Topic: M&W Piston/Sleeve Kits
    Posted: 11 Apr 2020 at 7:34pm
Looks good. I have M&W engine kits in two of my Deere 3020's and one 4020 diesel. They sure run good. In my soil you need to spend a day shinning up the plow bottoms before even thinking about plowing as the dirt will just stick. I was from Maryland and our soil there we could pull a plow out of the fence row where it was parked for 10 years and two rounds latter have it shinning like a mirror not here in WI. Tom
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 7:18am
Bump
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 11:09am
I have an old set for a wd, wd-45 etc. old stock still in box. was going to put them in the 45 with the stuck motor but will never get it done. ---back in the mid 60's everything had M&W in them.--big rage back then. ---Problem I see with the oversize stuff is that the starters never work after you put them in, pull starting is fine but takes 2 to do!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 7:10pm
So do those liners fit the stock holes in the block? 1/8” is a pretty big gain. And 6 hp is a big gain too. Must have different compression ratio as well for WD45?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:21pm
Yes Ed (Ont) they fit in the stock holes. 1/8 inch over and higher compression made a noticeable difference in the WD, WD45 and D17 that we used
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:25pm
I think they had a souped up starter to use with a M&W kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:35pm
Dad moved the brushes on the generator to make it charge a little more and used a 8 volt battery. Over the years I think we broke 2 starter noses. They did make a gear reduction starter but we never did have one. Puled 3-14 with the WDs and 4-14 with the 17 in some pretty tough ground. This was back in the 60’s
