DIY B mid and rear lift?
Runamuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Topic: DIY B mid and rear lift?
    Posted: 08 Apr 2020 at 8:36am
Hello everyone, it's been a while. I'm wondering if anyone has made a homemade lift that would work under a B. I have a '38 with no electrics or hydraulics. I want to be able to mount a simple tool bar mid mount and rear for cultivating and hilling where I can see it. I found a rock shaft and mounted it. There is a rooster comb welded by my right leg with lever and cable that runs over a pulley bolted down to the right of radiator that was used for an ATV snow plow lift, I believe. I have to find jobs for this tractor other than pulling a drag. Have a large garden where I'm always fighting nasty weeds, so this would be a huge help. Been staring at this rockshaft for 2 days trying to figure out a way to use it. Any suggestions would be appreciated, especially with pics. Thanks guys.
Bill
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 9:38am
I think I would hang more weight out off the back end to get a more solid bite into the soil.
The crank jack in the center should be able handle a lot of weight.
HTH
[TUBE]VJyUL2khGpg[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:06am
Thanks but what I'm thinking is something under the belly of my '38 B I can see looking down. Something with a hand lift like my L59s on my C s have. Maybe push tubes from the rear axle and raise/lower from the torque tube or vice versa. I figured with the age of these tractors there would be all kinds of improvised implements for the garden, but maybe I was wrong. Would like to have a basic tool bar I can leave on the tractor and change blades between cultivating, hilling, and potato plow types.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 9:52am
Maybe I'm reading this wrong but sounds to me like you need to find a set of cultivators for a B then modify to your liking. Been awhile since I looked at the cultivator frame I have but sounds like its does what you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 7:23pm
Yes, that's basically what I need. Hoped I could put something together with steel I already have, but it would be a lot of messing around. If I could find one reasonable not too far away, one that just bolts on would be the way to go. I've got some 2 inch square tube and old spring shanks I thought maybe would work; just have to figure out how to mount them.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 10:45am
My 38 B has a 1-row cultivator under it. Ready to run, Tractor and cultivator $1,000 Pick up in central Illinois.
