My Dream Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: My Dream Tractor
    Posted: 21 Aug 2010 at 8:08pm
This is the tractor of my dreams. I knew someone would eventually put a detroit in an Allis. Listen to this thing ROAR!
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 8:22pm
Its pretty cool, but an 8V would have been alot cooler than just a plain ol' 6-71.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 6:18am
We are on vacation and the campground Wi-Fi has blocked U-tube. Love the sound of the old 2 stroke Detroits. Owned a 8V-71 and a 6V-92T. Local guy has a show JD 5020 with 8V-71 power. Saw my ultimate farm truck a few years ago. 1971 GMC Astro with a 12V-71. I'd love to pull into my local elevator with a hopper B train loaded with 50 tons of corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 8:31am
the 238 still sounds good , like the sound . The HD17 I seen out in western MN with the 8V-71 looked like a nice machine also.
 Sometimes you go with what you got and if they had a 6-71 laying around why not use it.
Like the 2-71 I have that is looking for a new owner, would be great in WC I figured.
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 8:46am
Ok, that's sounds cool.  AC's always look better in the snow too I think.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 1:44pm
I think you guys are plain nuts.  Dad had an 8V-71 Cab over KW.  Nothing more than I wanted to do that shoot that ($)%# thing for making so much noise and leaking so much oil.  Only good side to it compared to every thing else was that parts were dirt cheap, but of course it loved the oil, at least a gallon for a good days run.
When I left the farm and joined the military I thought I was done with them screamers.  Only to my dismay that all of the support equipment was powered by 6-71's, 4-53's, and 6v-53's.  Always did get a good chuckle watching someone try to start one with the air door closed.  They would go to get someone from the support equipment mechanics and I would have it running when they got back;)
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 9:10pm
OK, that does sound pretty good from a distance, but I would hate to sit behind that screamin rascal all day long. Detroits just always sounded like it took them forever to get wound up, and then they sounded like they were gonna come apart. pretty good engines though, just keep the oil in 'em.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 9:18pm
that is wicked cool! sounds like he is upshifting more than just a power-director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 9:39pm
Serviced 3 Pete cabovers in the 70's all with 8V71 , 318 engines , one had 2 Mil on 2 overhauls  / in frame. one was 3 Mil and ready for 3 rd in frame.  Other was under 1 Mil and still running good. yes they leak if not sealed good and oil was what needed checking regulary.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 9:48pm
You know, I not trying to make you change colors or anything, but Oliver had a 3-71 option in their Super 99. 80 HP, torque converter, 6 speed.
Detroit is one helluva motor - its a fuel hog, but makes up for that by having higher rpm & a much broader power band - meant fewer gears were needed for some tasks. A military surplus Huber Warco road-grader we had at the airport worked its arse off every day and would lug down far better than the 4-stroke diesels. All it had was 4 forward gears - but you could pick just about any one of them and throttle down to a crawl and back up without ever hitting the clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 9:52pm
CJohn S MI, Dont worry I already have an Oliver 70. Hey do you know the number for 911? I need to report a theft. LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 10:00pm
The number for 911 is...
911 !!!
I only ever saw one Oliver in my neck of the woods where I grew up - a kid down the road had one that was gas start/kerosene run & was caught numerous times stealing gas and broke down on the side of the road. Seems he never figured out that manifold would cook the gas once it got hot & kerosene by that time was hard to come by.
Nowadays, in the Thumb area of Michigan, I see Olivers all over the place.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2010 at 10:59pm
I've got a 67 ford  single axle semi-tractor with a 6-71 in er, and  (knock on wood) never had to add a drop of oil to er, cept for oil changes. Just run her with my foot flat on the floor
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 5:27am
My dream tractor won't be fitted with a Detroit, otherwise it sounds good. But my number one will be a D21 fitted with a V8. Sad that Allis didn't made that from factory, just like IH and Oliver did.
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
