Help electrical 7030 |
Post Reply ![]() |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2558 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Mar 2020 at 11:16am |
Where might I find circuit breakers for 7030? I pulled my new to me out of the shop so the guys could put new tires on and lost power to radio, wiper, blower. I have the owners man but that doesn’t help me. Thanks, Dana
Blue Skies and Tail Winds
Dana |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8590 |
Behind lower dash panel on 8000....don't know about your.
youngorange2000 ![]() Silver Level ![]() Joined: 27 Mar 2019 Location: eastcentral MN Points: 314 |
I had a ih 5288 were the cab relay ground was rusted and would make contact very intermittent, I just shined up the grounds and put a new ground bolt in and its been working fine scenes. It might just be a bad or loose ground somewhere
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21776 |
Main breakers are directly straight ahead of the brake pedals in the engine compartment. There is a breaker on the key switch inside the instrument panel. The power begins at the starter terminal stud with a heavy wire that has a soldered connection inside it (fuseable link) and goes to the main breakers.
OK Dic I see a junction box where you said in engine compartment ahead of the brake pedals but I see nothing resembling resettable cb’s?? Also do I have to get to ignition switch cb by removing metal panel underneath switch? Thanks!! Dana
Dana |
Proof read Dana LOL....breakers are not push button reset....they reset when cooled off.
Edited by SteveM C/IL - 29 Mar 2020 at 12:58pm |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2374 |
There are breakers in the top of the cab,under the roof that control blower,wiper, and radio. There may not be power to them.
Not Sure what’s going on here when I turn the key I have power on the dash lights I just don’t have any power above my head also I’ve vacuumed up on top and I saw no breakers but again up under the roof are they reset-able? What do they look like. I tested up by the controls in roof and saw no power tell me foes the ignition switch need to be on for those to work or are they hot all the time? thanks again as usual. Dana
Dana |
OK y’all here’s the thing. I’m 76 inches tall. How did the boys figure I could work on the floor of that cab? LOL! I laid upside down and could barely see the cluster of ‘things’ hanging off that ign switch. I felt around gingerly (with the key switch on and radio and blower on and all of a sudden they came on. I thought the issue was in the switch or wires on it and so it is. Now I guess I’ll try to find a tiny person to see what’s up. OMG I just remembered the switch seemed real dry so I shot some dry spray lubricant in the keyway a few days ago! That must be it! Now what? Compressed air through keyway? Km
Dana |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3894 |
Lights are powered from batteries through breakers on firewall. Key on for power overhead. Breakers under roof for A/C and wipers...
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
I had the throttle chafe through the feed wire to the cab top once. Sometimes it worked fine, sometimes it didn't and sometimes it was a dead short. Took me a while to figure it out, but fixed the wire and fixed the problem
Thanks guys it’s in my ign switch. We will see how it goes I’m leaving the panel off under steering wheel, if I do replace the switch I have no idea who I’ll get to fit in there to work I sure don’t fit lol
Dana |
Post Reply ![]() |
