Will 15X28s Fit ?
SGTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SGTJ Quote  Post ReplyReply Direct Link To This Post Topic: Will 15X28s Fit ?
    Posted: 15 Mar 2020 at 7:37pm
I've had my eye open for awhile now,  on the hunt for a new set of tires and rims for my WD.   Haven't found the rims yet -- but there is a guy selling a shed full of tires, and he has a couple sets of 15x28s.
I currently have 13.6 x 28s  --  and before i start spending money i'd like to be sure they'dfit,  or if there is any down side.
thanks in advance
-Zac
WD , CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 7:46pm
Be aware that if the sidewall size is 15-28 that is equivalent to the new tire size 18.4X28 and mounts on a 15" rim. That's a lot of tire for a WD.
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 7:56pm
The rims will never be wide enough for those tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 8:32pm
I just put new rims on my D17   16.9x28 tires rims cost me 330 each for the power shift type .They look really nice flat side walls and stand up right.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 8:41pm
I put 14.9x28 on my WD.... rims and tires from a 45 and I can't move the tires to narrowest position without the fender mount plates from a 45 to get the fenders higher so the tires would hit. 18.4x28 will be even worse for that if that matters to you.
Wink
I am a Russian Bot
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 2:14pm
This is my WD with new 14.9-28 on 13" rims this past summer. I can't put them all the way in without hitting fender, personally I think they're just right and wouldn't go bigger.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 4:59pm
Not only don't fit right, but kills your horse power. Road speed,--ya ups that but the old motor wont hack it.
Your tractor, so do what you like, mine are 14.9 and I wouldn't even think about bigger on them.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 5:11pm
He said 15" wouldn't that be 14.9's?  They should fit fine and plenty of adjustment on the rims.  Probably not all of the way in.  The problem I see is they are not mounted so you can't tell how weather checked they are.  You can run your had around them to see how dry rotted they are.  If they don't have the little nibs on them, I wouldn't but them.  If they're in a barn, chances are they are probably used to about their limit and not worth anything except to make a rolling project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 5:33pm
NO!  A 15-28 is the same as an 18.4 in today's numbers. WAY too big it fit well, and need 15 inch rims at least.
Edited by CTuckerNWIL - 16 Mar 2020 at 5:34pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 6:03pm
That is a nice looking set of tires on your 45!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 7:46pm
Actually the 15-xx needs a 16 inch rim according to the chart.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 8:53am
I've got 16.9X28s on one of my 45s, love them. 18.4s would be a bit much, though I do have a set of 'placeholder' 15X26 wheels and tires. They are not spin-outs and fit the fenders fine, actually taller than my 16.9X28s. I also have a set of fender mount brackets that have spacers welded to them so you can move the fender to the inside letting the tires spin in farther.
Attached is a pic of the 45 when it wore the 15X26 rubber. Man that old girl has changed a lot since then!
