How much to fix this mistake
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Topic: How much to fix this mistake
    Posted: 10 Mar 2020 at 1:51pm
Some days you should just stay in bed. Hoping for pictures but my help on that is hiding. Besides it is a green tractor Wink you guys didn't want to see it anyway.
So I was burning a brush pile and piece of 3/4 inch pipe in the mess. It got just right to have pipe catch the throttle linkage and bent twisted and broke the L shaped arm that is on the shaft coming out of the governor on the injection pump.
It is a Yanmar hiding as John Deere 1250. The pump is a Yanmar, 721820-51300     952  5D  017. From looking at the parts book John Deere does not service any of the parts except as a whole pump. Which I am not ready to think about,Cry just yet anyway.
The arm could be hammer out and the linkage straightened. But the connection to governor is a bushing that has spring pin hold it together. The bushing broke in half and the shaft is bent just a little.
If I was good at fine work I might get a new bushing drilled in the right place. But looking for other options. Hopefully InjpumpED comes along and has a pile of arms that would fit he could sell me. But the way things have been going, I probably have one of a kind pump and no parts left in the world.
The pump and everything still works. I put a vice grip on the shaft and a bale wire to drive it home 2 miles from the old one room school house I was working at.
It was really maddening as I had it in low gear moving several stumps,Wink very carefully,just not carefully enough.  Looking at barbwire and other stuff that could poke into a tire. Since I was out in public i kept the pile little like "Air Quality Control Board" had asked. Wink Burn the bigger stuff in a wood stove,which is not illegal yet. If I would just put a match to the whole works.
Wink But it did not happen when was pushing into the fire at least.LOL
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 8:41pm
Give Hoye Tractor a call
940 592 0181
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 4:52am
I would look to a junkyard that has similar size engines, Japanese diesels use japanese pumps, so find a boneyard for lil tractors, or maybe diesel reefer units, or small construction equipment.  Yanmar engines are used in these applications...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 11:34am
Thanks guys never would of thought of the reefer units.Smile That why I asked that extra brain power, i sure did not use much to other day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 12:09pm
if you can get a real parts breakdown and finds real part numbers, google 'part number' and see what comes up.... same part could be used in 4-8 models, 3-5 makes so maybe 40 chances to find the part....
