D12 Backhoe project completed
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Topic: D12 Backhoe project completed
    Posted: 07 Mar 2020 at 7:13pm
Would like to spray hoe orange but that is a LOT of masking !Hoe mounted to sub frame ,3pt. removed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 7:25pm
Nice setup Burl!  Beautiful job!!
Steve@B&B
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 7:35pm
Very nice¡
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 7:55pm
Originally posted by Reindeer Reindeer wrote:
Very nice¡
I'd have to agree, looks pretty sweet!
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 8:34pm
Thank-you - Should have put these at top but, the story is, I picked it up 30 min. before it went into crusher . Got lucky !
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 8:44pm
thats a nice looking rig looks like you did some nice fab work, i am guessing that you had to biuld all the hoe attachment mounting .     what brand is the hoe attachment ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 8:47pm
missed that veermer ont the top
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 8:51pm
It took me 4 weeks to make subframe . I made it all out of wood before fab. the steel parts . Its a Vermeer hoe off a trencher .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2020 at 11:13pm
With all the obvious work fixing that tractor up it's no time to go wobbly on painting the hoe. Get to masking and maybe some careful aiming and you will have it matched up in good time. It will be worth it when done. I assume it's more work to remove than to mask.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 7:28am
You did a great job. You have come a long way from where you started.
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:04am
Great job saving it! It looks great maybe I’m just biased to anything D series but that little tractor is on my list to have..!!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:36am
Good save, great work, and I know you'll paint it. You just want to enjoy it for a bit, who ya gonna bury first. Wink
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:46am
Thanks again ! The hoe can be removed or attached in 15 min. I use alum. foil to wrap hyd. hoses but , where they all come together on control body is a nightmare !
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:49am
Very nice looking set-up.
Have you considered repainting the tractor to match the Hoe.
I believe the I-40 and I-400 were a yellow similar to the Hoe.
https://www.mylittlesalesman.com/1972-allis-chalmers-i400-tractor-10109193
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 8:55am
VERY NICE............. a few resize
Cernunnos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 9:30am
Great save from the crusher!  What brand are the front wheel weights?
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 12:25pm
Thank you Steve , I never can get them correct . Wheel weights are IH . $40 for the pr. I like Orange !! Maybe spray hoe this summer if I get caught up.Would look nice with AC decals & paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 4:17pm
That is GREAT work Burl.  Yeah, you'll paint it.  It's gotta match!
Did you get the weights in the pic too?
GeneD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeneD14 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 7:02pm
Nice job mounting the backhoe. I like that you used a sub-frame, instead of just using a 3-point mount.
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 7:11pm
Did not get any of the suitcase weights on ground. It did come with custom railroad track weight chained to front axle. I did make that 4 in. sq. tube hanging from front axle. Filled with melted lead auto wheel weights, ended up weighing 90#.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 10:40pm
Of course you need a loader on the tractor to balance it and make it easier to refill the hole the hoe dug.
Allis Express participant
