700 D Engine Info
tkelley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkelley Quote  Post ReplyReply Direct Link To This Post Topic: 700 D Engine Info
    Posted: 04 Mar 2020 at 4:06pm
I have a customer who owns an Allis Chalmers 700-D Rough Terrain Forklift. It has the engine serial no of 85130L. I need to know Engine Make, Engine Model, and Horsepower. Any help is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2020 at 4:15pm
Pretty sure the "D"-series was the Allis-Chalmers 433-T or 433-TI  4 cylinder turbo diesel.   Should be an engine tag plate under the thermostat housing on what would be the left side of the engine if it was in a car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkelley Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2020 at 5:10pm
I looked all around and couldn't find anything. but I'll look there and see if it's in that spot. thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 7:12am
Is it turbocharged or not ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkelley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 2:24pm
I'm not sure if it is turbo charged. and I couldn't find a data plate anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 2:34pm
Well, I think the best thing for you to do is give us some pictures of the machine and the engine from several angles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 3:38pm
The 700 "D"-series consisted of models 705-706-708 and 766. They all have the Allis-Chalmers 433-T 4 cylinder turbocharged engine which would have been very similar to the 6060 farm tractor engine and rated at probably 80 to 85 flywheel HP.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 3:03am
Sounds like your 700D may have a Perkins 4.236 Diesel engine? Perkins uses letters in their serial numbers to denote engine type, engine’s country origin mfg, & engine year mfg. If it’s a Perkins, it probably has another number directly above it’s serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 7:24am
I'm thinking he has a 700-Diesel, not a 700-D series.    A model 700 would be a Perkins, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkelley Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkelley Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 11:08am
those are two of the pictures i was sent by the customer. none of the actual engine. I can go get some but it wont be til next week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 11:13am
That should be a Perkins engine. That isn't the newest (and last) "D"-series that were turbo diesel only. It's an older version and is a "D" designation because it's a diesel not a gas engine.
Edited by DrAllis - 06 Mar 2020 at 11:13am
This page was generated in 0.091 seconds.
