8030 Rear Drive Oil
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Rear Drive Oil
    Posted: 19 Feb 2020 at 8:04am
Hello All,
New to the forum, and after owning a Gleaner L3 and a 185 for a bit I decided I better round out the AC collection by purchasing an 8030 FWA.
Newbie question; what is the recommended oil for the 'Rear Drive'? I'm talking the bit at the back with the sight glasses on the left side of the PTO housing.
She's a power shift if that makes any difference.
Help is appreciated, Matt
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 12:31pm
I use Cen-Pe-Co hyd oil. Not sure if that is sold in Canada. Other good quality oil, not the cheap stuff, will be good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 12:40pm
Thanks, I wasn't sure if that part of the transmission was filled with the same stuff as the front....but apparently it is.
After some digging I found 'Allis Chalmers Power Fluid 821' as the official lube required.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 12:59pm
Yep, couldn't remember the number, that would be the one.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 6:56pm
Chevron THF
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 9:47pm
some of the farm store oils list AGCO 821 on the bucket
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 6:52pm
Don't use the cheap 303 oil, it freezes up and way too thin
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 10:30pm
303 doesn't list equivilent to 821...but you are right,that is not hydraulic/wet brake oil
