D19 camshaft
ditchman24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ditchman24 Quote  Post ReplyReply Direct Link To This Post Topic: D19 camshaft
    Posted: 17 Feb 2020 at 8:39pm
What is the difference between a D19 and a D17 Diesel cam? Someone mentioned that a gas cam would work or more power? In a diesel. In need of a cam for my D19 Diesel. Looking for some options.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 3:49pm
74516085 shows to be the cam for the D17 and D19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ditchman24 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 5:28pm
Is that the diesel cam? Someone mentioned running a gas cam in the diesel. Dose anyone have any specs on the different cams? Just wondering how different the gas is from the diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 6:07pm
lift on valves are the same gas vs diesel
gas intake opens 27 deg BTDC closed 57 deg ABDC
diesel intk   opens 10deg  BTDC  close 38 deg ABDC eff sn D 01499
 "       "          "     30 deg   "         "      40  "     "     prior to D-01499  these were mostly
        changed out
gas exh  opens  59 deg BBDC  closes  25 deg ATDC
diesel "     "       40   "    "          "       15 "       "      Effective SN
  "      "     "        50 deg  "         "       70 "      "       Prior  sn
the theory was with turbo the  more valve opening the more HP - and it did - but it took a can of ether or gas or TNT to crank one north of the mason/Dixon line in the winter.
ME thinks the gas cam might just give more hp... but at the expense of ez starts. We have had D19's on the dyno's through the years and can get 80 hp by advancing the timing on the pump - but they will not start. When timed to start they will pull 65-70 hp with the late cam.  We never dyno'd an early cam that we know of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ditchman24 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 6:58pm
Thanks for the information. That answered my questions. I need to find me a diesel cam then. Iowa gets pretty chilly now and then.
levipatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levipatch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 7:22pm
That is very interesting and not what I expected... Good imfo ... I like!!!!!!!!!!!!
Billy..Big cam 300, bcam 400,,941 CAT.,,Deere excavator..900 row crop.. 66 D 17 diesel IV... 985 Pratt and Whitney..4360 Pratt and Whitney... gitten tired !
This page was generated in 0.199 seconds.
