D15 Radiator - Are Series 1 and S.2 interchangable
KYrod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Topic: D15 Radiator - Are Series 1 and S.2 interchangable
    Posted: 13 Feb 2020 at 12:14pm
All the parts places have radiators for the D15 but they all say they're for Serial numbers AFTER 9001....which are series 2.
I have a series 1 (sn 5227) and I'm thinking of buying a new radiator.
Anyone know if these radiators are interchangeable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 12:26pm
I think they are the same EXCEPT, there is no provision for the front mounted headlites to screw into. I say I THINK that is the only serious difference.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:37pm
Just get your old one recored.  It will be as good as new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 8:29pm
$650 locally. Seems high since I can get a new one for the same price.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 9:04am
I bought an after market. I had to shim up the radiator so the neck would come through the hole to get the cap on and drill four holes to get the sheet metal bolted on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 9:36am
That was a D-15 after-market radiator ??   Who was the supplier  ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 10:15am
Just to clarify....are you addressing my original question about compatibility between D15 (GAS) series 1 and series 2 radiators?
It sounds like you're saying you bought an aftermarket for Series 2 and you were able to modify it to work on a series 1....is this correct?
Like Dr. Allis, I also would like to know the supplier and the manufacturer. I'm finding that some of these radiators are made in Turkey????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 11:01am
There's no difference in sheet metal height, width or size between S1 and S2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2020 at 11:45am
Yes, series 1 and 2 rads fit the same - no problems there. However, as stated above, new aftermarket radiators do tend to have fitment issues and tend to be made overseas.
That is why I recommend getting yours recored. Guaranteed to go back on with no issues, they are done locally and are about the same price. You would never have to touch it again either.
